Step 1: What do you need?
- Some sort of iron frame or garden rack, size depending on the space available
- Wood:
* 4 - 6 pieces of approximately 10 x 5 x 5 cm to hold the garden rack from the wall
* Planks of slats to line the frame
- A sheet of plastic
- Jute cloth to hold the earth. This should be the size of the garden rack, plus an extra 20 cm on the long sides
- Paint, or something else to protect the wood against the weather
- Screws, dowels and some cramp-irons and small connection strips or corners
Tools:
- Drill
- Hammer
- Screwdriver
- Saw
Step 2: Preparing the wood
The planks will be used to line the frame and make it more solid so it will later hold the weight of the earth back. Saw the planks at the right size to fit the frame. In the end you will get three pieces: a short one for the top of the frame, and two long ones for the sides.
The blocks (approximately 10 x 5 x 5 cm) will be used to attach the frame to the wall. Because you will use the long sides for this, get long nails (around 15 cm). Drill a hole through the wood using a drill with a diameter slightly smaller than the screw, then put the screw through.
Step 3: Preparing the garden rack
Step 4: Preparing the wall
To protect the wall against the roots of the plants and against humid getting into the wall I put a piece of plastic sheet on the wall were I will later attach the vertical garden.
Step 5: Attaching the jute cloth
Start by taking one of the wood blocks and the jute cloth. Put the screw through the corner of the jute cloth, and then screw it into the plug you've put in the wall at step 4. Before you do attach the block to the wall, check if you have enough jute to attach the other side as well.
Then take the second one and do the same. The last two will be a bit harder to attach because the cloth will be in you're way. But although jute is not elastic, it's flexible enough to be pulled over the blocks when they're attached firmly to the wall.
Step 6: Fixing the frame
Now just cut away the excess plastic sheet around de vertical garden and the garden is almost finished.
Step 7: Put earth in and start planting!
For planting: use small seedlings, but not so small they're still very vulnerable. Cut a small hole in the jute and put the plant in.
Step 8: Some tips for the pro's
- I put tomato plants (I know, not perennials) the first two years and they did extremely well. The second year it was harder to put the plants in because the earth had dried out over winter.
- I've just build my second vertical garden and because dehydration is a problem I will build in some 'irrigation': a waterhose with small holes in it that can be used to water the garden from the inside.
- cover the top of the garden with some straw or other type of mulch, to prevent dehydration form the top. Also this will slowly decay and work as compost.
Visit Our Store »
Go Pro Today »
Check out Compact Rotational Gardening with Raised Beds also designed for planting fruit & veg in small spaces. Although I have to admit that it's not quite as compact and convenient as your design! Well done :)
I picked up a couple of the Felknor Ventures Topsy Turvy Planters.
Though i have yet to use them yours looks great and can obviously grow a lot more strawberries or what have you.
In thinking over the issue of evaperation - the Topsy Turvy Planters are made with a tarp type material - perhaps this would help keep the water in as opposed to the jute material?? Just a thought you may want to try on your next one or an additional one - to see what works best.
As well your ideas on soil additives sound like they are on the right track to help with this issue as well.
FYI...My topsy turvy didn't do well and I was wondering if it was from using non-breathable fabric. In hotter climates I think the non breathable fabric traps heat and moisture and caused high temps and mildew. Just thought I'd share that.
Well perhaps partial shade for the Topsy's will help them... i'm in a tropical area with lots and lots of sun currently. So thanks again for your experience with them.
Well then i don't have another suggestion for the water evaperation issue you're having with your Garden wall.
I'll have to think on it a bit - see what i can come up with - perhaps a thought or two after visiting the local growers center. If i come up with anything that may help or you might want to give a try - i'll post it.
ahh - wait - maybe a simple poly styrene sheet will help and insulate - between the dirt and the cloth - they come in 2 ft x 4 ft x 3/4 inch at Home Depo and Lowes...
just a thought... maybe worthless - but - a thought none the less.
;0)
I'll try! promise to upload a picture!
'Indeterminate types are "tender" perennials, dying annually in temperate climates (they are originally native to tropical highlands), although they can live up to three years in a greenhouse in some cases. Determinate types are annual in all climates.'
I'm from a temperate climate, so they die when it gets colder...
Covering walls with vines is a great way to increase insulation, too. Supposedly it reflects up to 70% of the sun's rays in summer and prevents up to 30% of heat loss in winter. It also prevents structural materials from UV damage. There are buildings in Europe that have been preserved for many hundreds of years by being covered with vines. I'd be careful with vines right up against wooden walls, but you could certainly back them off a few inches and still get the insulative benefits.
