Remove these ads by
Signing UpStep 1What do you need?
- Some sort of iron frame or garden rack, size depending on the space available
- Wood:
* 4 - 6 pieces of approximately 10 x 5 x 5 cm to hold the garden rack from the wall
* Planks of slats to line the frame
- A sheet of plastic
- Jute cloth to hold the earth. This should be the size of the garden rack, plus an extra 20 cm on the long sides
- Paint, or something else to protect the wood against the weather
- Screws, dowels and some cramp-irons and small connection strips or corners
Tools:
- Drill
- Hammer
- Screwdriver
- Saw
Check out Compact Rotational Gardening with Raised Beds also designed for planting fruit & veg in small spaces. Although I have to admit that it's not quite as compact and convenient as your design! Well done :)
I picked up a couple of the Felknor Ventures Topsy Turvy Planters.
Though i have yet to use them yours looks great and can obviously grow a lot more strawberries or what have you.
In thinking over the issue of evaperation - the Topsy Turvy Planters are made with a tarp type material - perhaps this would help keep the water in as opposed to the jute material?? Just a thought you may want to try on your next one or an additional one - to see what works best.
As well your ideas on soil additives sound like they are on the right track to help with this issue as well.
FYI...My topsy turvy didn't do well and I was wondering if it was from using non-breathable fabric. In hotter climates I think the non breathable fabric traps heat and moisture and caused high temps and mildew. Just thought I'd share that.
Well perhaps partial shade for the Topsy's will help them... i'm in a tropical area with lots and lots of sun currently. So thanks again for your experience with them.
Well then i don't have another suggestion for the water evaperation issue you're having with your Garden wall.
I'll have to think on it a bit - see what i can come up with - perhaps a thought or two after visiting the local growers center. If i come up with anything that may help or you might want to give a try - i'll post it.
ahh - wait - maybe a simple poly styrene sheet will help and insulate - between the dirt and the cloth - they come in 2 ft x 4 ft x 3/4 inch at Home Depo and Lowes...
just a thought... maybe worthless - but - a thought none the less.
;0)
I'll try! promise to upload a picture!
'Indeterminate types are "tender" perennials, dying annually in temperate climates (they are originally native to tropical highlands), although they can live up to three years in a greenhouse in some cases. Determinate types are annual in all climates.'
I'm from a temperate climate, so they die when it gets colder...
Covering walls with vines is a great way to increase insulation, too. Supposedly it reflects up to 70% of the sun's rays in summer and prevents up to 30% of heat loss in winter. It also prevents structural materials from UV damage. There are buildings in Europe that have been preserved for many hundreds of years by being covered with vines. I'd be careful with vines right up against wooden walls, but you could certainly back them off a few inches and still get the insulative benefits.
