Step 5Attaching the jute cloth
Start by taking one of the wood blocks and the jute cloth. Put the screw through the corner of the jute cloth, and then screw it into the plug you've put in the wall at step 4. Before you do attach the block to the wall, check if you have enough jute to attach the other side as well.
Then take the second one and do the same. The last two will be a bit harder to attach because the cloth will be in you're way. But although jute is not elastic, it's flexible enough to be pulled over the blocks when they're attached firmly to the wall.
Add Comment
