3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vertical Garden from Free Recycled Styrofoam
Vertical Gardens aka Living Walls can look absolutely stunning. You can have a garden growing right up your wall indoors or outside.
Grocery stores get some of their food shipped in 100% food safe styrofoam boxes that work perfectly for making your vertical garden. This instrucable will show you how to make a vertical garden that's modular, easy to water and has endless options for making world-class frames for your vertical garden. It's basically made out of a styrofoam box and a cheap non-toxic easy to use coating.
I’ve also included some different options you have in building a living wall so that adds to the length of the instructable.
First you’ll need the following:
*For some of the foam supplies, you can go to livingwallart.com
**Disclaimer: Livingwallart.com is actually my blog and I have the diy plan listed there as well... but I wanted to add an instructable here as well because I thought people would find it useful. The supplies I used to build this you can also get at www.hwff.com. They're the manufacturer of the foam coat... I just made it easy to order (for the same price) off the blog so if you like the plan and want to support the blog, you can get it at livingwallart.com as well.
  • Foam - Step 1 gives more specifics
  • Foam Coat - A non-toxic easy-to-apply coating that adheres to foam and makes a hard casing. Cleans up with water.
  • Boost or Bounce - A liquid that can be added to the foam coat to make it waterproof. It’s non-toxic
  • Foam Fusion – A liquid glue that won’t melt foam over time. It takes a bit to set, but once it sets it’s waterproof and will go the distance.
  • Something to cut the foam with – A hot wire foam cutter will slice through foam like butter and there’s no foam pellets to clean up after. An X-Acto knife will work, and you could even use a knife from the kitchen, but foam will be flying everywhere – you were warned =)
  • Paint brush or putty knife/drywall trowel and tupperware container.
  • Paint - if you so desire. The natural colour is a very light tan. Painting it also helps make it more waterproof.
  • Plants and potting soil
  • Two screws, two anchors, a ruler and a drill – all for hanging it.
Step 1Get the foam
Get the foam! - Your two options are to go the recycling way and the regular buy at the store way.
  • The recycling way - go to your local grocery store and go to the meat/fish area. Meat and fish are typically delivered in FDA approved 100% food safe foam boxes and will typically be thrown out. All you need to do is ask someone behind the counter . My grocery store typically has about 5-6 boxes they throw out everyday before 5:00 pm. The boxes vary in size and I try to get the boxes around 9″ x 24″ x 6″ and have a lid. After you get them, just rinse them in soap and water to clean them out and let them dry and you can to go step 2.
    One of many sizes you can get for free
  • If you go the regular buy-at-the-store-way, you should be able to find the foam you need at Home Depot. Often times it’s around the insulation section of the store. The Home Depot here allows you to buy sheets of white EPS foam. EPS foam is the best to work with typically, but you’re welcome to try other types. You need to then make a box around 9″ x 24″ x 6″ in size.
7 comments
Feb 16, 2012. 8:44 AMAlabastorian says:
Just a public health notice:
Do not apply chemicals or heat to foam in any space that is not very well ventilated. The the resulting airborne chemicals can make you very very sick.
Apr 16, 2011. 10:47 AMblauschmetterling says:
Is foam really the best thing to use? I've tried using foam trays as drip pans and every plant on the foam has died. Styrofoam is highly reactive and will actually disintegrate when exposed to certain substance.
Nov 29, 2009. 11:13 PMl8nite says:
Some of us are to dense to follow along with all the instructions if there aren't any pictures.  Others like to look at the pictures first then if they can't figure it out read the instructions( or in the case of some of the electical ibles to see if its beyond our skill)......... I fit all 3.....Its a shame because you did a LOT of typing!  Personally I'd like to see the boxes you'r referring to, how you apply the sealer, how to attach the boxes and how to fill them
Nov 29, 2009. 8:46 AMlemonie says:
You might have changed the wording a bit, but it's essentially a copy of this page and you haven't any pictures of you doing it. Did you make one?
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:isupereco(Living Walls)
I love urban gardening
