Vertical Garden With Reinforced Pouches
Introduction: Vertical Garden With Reinforced Pouches
This Instructable is for a DIY vertical garden using an Ikea waste basket as the base. Adding woven plastic to felt pouches strengthens and adds a water-resistant capacity.
These instructions are for one pouch, but in the pictures I made two. Make even more than that!!
Step 1: Accumulate Materials
You'll need:
  • Plastic bags
  • Ikea Variera trash basket
  • Heavy duty felt
  • Iron
  • Parchment paper
  • Scissors
  • Grommets
  • Hammer
  • Zip ties
  • Needle
  • Twine
  • Potting soil
  • Plants
Step 2: Disassemble Waste Basket
With scissors,
  • Remove and discard side wings from the waste basket
  • Remove and discard base
Step 3: Weave Plastic Strips
Woven plastic bags give strength and water resistance to the pouches.
  • Cut plastic bag into strips
  • Arrange strips into tight woven pattern
Step 4: Heat Plastic
With iron on low setting,
  • Heat plastic between two sheets of parchment paper
  • Once cooled, trim rough edges off plastic squares
Step 5: Make the Felt Pouch
Make the initial felt pouch
  • Cut felt into the a rectangle roughly 8.5 by 7.5 inches
  • Fold felt in half, leaving roughly 1 inch at the top and pin in place
  • Using twine, sew along the two sides
Step 6: Add Plastic Reinforcement
Position the plastic over the front (shorter) edge of the pouch
  • Using twine, attach the plastic to the felt pouch at the top two corners
  • Wrap underneath the pouch and knot to the back stitches
Step 7: Add Grommets
Along the top of the pouch,
  • Place the grommet base and tool on the right side of felt where you wish to create the holes
  • Pound down in one fell swoop (watch your fingers!) and puncture felt with tools
  • Repeat on left side
Step 8: Attach Pouches to Base
Using two zip ties
  • Loop zip tie through the right grommet to the Ikea base
  • Repeat on the top left side A
Step 9: Add Plants!
In the pouch,
  • Place potting soil
  • Remove plants from pots and secure in the pouch, making sure the plants are turned forward
And display!
  • You can remove adhesive on the back to attach to wall, or hang
  • Make multiples to create a full wall garden
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Pretty cool idea, thanks!
