Vertical Laptop Stand
13,762
231
23
Posted
Introduction: Vertical Laptop Stand
Make a vertical laptop stand (inspired by Twelve South's BookArc). Positioning a laptop vertically reduces heat buildup on the bottom and allows it to run much cooler!
Step 1: Measurements
Measure the thickness of your laptop. If you use calipers, I suggest applying some tape on the jaws to avoid scratching your computer.
You'll need to do some calculations to determine the size of all the pieces. All the measurements are in the PDF plans: http://fasteasysmarttool.com/laptop/
Step 2: Step 2: Cut Pieces to Width
I cut down a sheet of 3/4" plywood to a manageable size. Then at the mitre saw, I cut two thin strips (1"), and one thick strip* (2 5/8").
*These dimensions should be adjusted for your laptop per the plans in step 1.
Step 3: Cut Pieces to Length
The mitre saw table is adjusted to 22.5°.
I apply masking tape to the plywood to control tearout.
Step 4: Sanding
Prepare the surfaces for gluing.
Step 5: Tape the Bits Together
Use masking tape to hold everything together before the glue-up.
Step 6: Test Fit
Perfect!
Step 7: Glue-up
Apply glue to all the joints. Let it set overnight.
Step 8: Glue Clean-Up
Clean-up any glue squeeze out, and break the edges with sandpaper.
Step 9: Route Cable Holes (Optional)
On the router table, I cut a slot on each side for cable management.
Step 10: Strength Test!
To be honest... I'm surprised it didn't break :)
Step 11: Apply Finish
I'm using enduro-var. First I pre-raise the grain with water. Then I apply two coats of finish, sanding between each coat.
Step 12: Done!
Your laptop has a new home!
Step 13: Video
Here's a video of the whole process.
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
18 Comments
A big space saver too! You can place 4 laptops were you can normally placed one.
Wow! That is such a clever idea! Great job on the Instructable, Especially because this you first one (let's not compare it to my first one, I didn't even know how to use steps)
What's that sanding thing that you used at step #4?
Nothing special, it's a sheet of sandpaper for my 6" random orbit sander. When mounted on the tool, the holes are for dust collection. I just don't bother to buy the sheets anymore, so I use those pads for hand sanding as well. I can see why it might look funny :)
I think this is the solution to my problem.
