3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tombstone Making
Tombstone Making
Almost ready for Halloween, but you find an empty space in your yard you just can't fill? Add a foam tombstone! I'll show you how to make your very own hot wire foam cutter for cutting the shape, how to carve out the letters, and how to paint your creation!
Step 1The HotWire Cutter
The HotWire Cutter
The first thing we'll make is the HotWire Cutter. You could try using a saw to cut the foam, but if you do that, you'll find yourself in a wonderland of statically charged snow. What you need is a Hotwire cutter! The one you'll make has a vertical wire and deep throat so you'll have no trouble carving even the most elaborate designs. You can vary most of the dimensions to fit your needs or preferences.
Materials:
- A short (about 6" long x 1.5" x 1.5") piece of wood
- A long (about 18" long x 1.5" x 1.5")piece of wood
- A plywood base (about 1' x 2')
- Thin craft wire (24-gauge or smaller, I think)
- Electrical wire
- Rubber feet
- 2 small eyelet screws
- Power supply (mine is 12VDC, 1.2A)
- Ruler
16 comments
Oct 27, 2010. 11:40 AMORDuckFan says:
I love the idea of using a hot glue gun tip for carving the letters - we tried to use the same effect by liberal use of a sharpie pen to melt the foam, but yours is better.
For a "really" weathered look, we have tried painting the letters with a small paintbrush dipped in gasoline. You have to go very slowly and cannot do fine details - but it achieves the desired effect.
Dec 3, 2010. 1:06 PMdrawe21 says:
A paint brush dipped into gas will melt foam in fast. (Found that out when I was young and getting gas from dads car)
Sep 20, 2010. 2:19 PMWalke2jd says:
What kind of foam did you use (looks like maybe the pink insulation foam sheets?)?
Also, how do these hold up outdoors? I decorate Oct. 1st and leave it through Halloween. Any way to add laquer or some other protectant to get more life out of these?
Awesome instrucable!
Oct 12, 2009. 8:24 AMjumpertoad says:
who can die of a splitting headache?
Nov 10, 2008. 1:05 PMxboxteen01 says:
This is pretty cool. But not to ask a dumb question but what are the consequences of making something like this? Electrical shocks, house fires, etc. Ive never seen the plans for one before so for all i know this could be the only way to do it. Good Instructable though.
Oct 18, 2008. 7:45 PMzachninme says:
Awesome job!
Just a suggestion: you might want to rename the instructable to just Hotwire Cutter, because this could obviously be extended to general foam cutting. (And you'll probably get more hits ;-)
Oct 18, 2008. 9:25 PMzachninme says:
The problem is more of someone searching for the latter, finding this, and thinking it won't work. Its just my opinion, though. I'm waiting for the tombstone-making instructable...
Oct 19, 2008. 4:47 AMKiteman says:
If you change the title, you will not change the url.
Oct 18, 2008. 8:07 PMHands Without Shadows says:
Make the wire longer than you need to and you will be abl to vary temperature a bit by changing your electrical connection points. A spring or weight is recomended because your wire will stretch a good inch once it gets hot. I rigged something like this up once to cut out a scale car body for an art project. I used a guitar string (e string if I remember correctly, would try a B next time), a computer power supply, some alligator clips, scrap wood, and something heavy to maintain tension. It was fantastic.
Oct 18, 2008. 6:44 PMrimar2000 says:
I suggest you to add a spring in the lower extreme of the wire, so that when this stretch upon being heated can continue tense. Under the table, it is invisible. GOOD INSTRUCTABLE.
Oct 18, 2008. 8:02 PMPadlock says:
haha. you said deep throat... "The one you'll make has a vertical wire and deep throat so you'll have no trouble carving even the most elaborate designs."
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:Radioactive_Legos
