Counterweight Balanced Hanging Planters
Introduction: Counterweight Balanced Hanging Planters
My office mate Chris G. and I wanted some hanging planters, but we wanted to be able to hang them higher than we could easily water them. So we made these counterweight balanced vertically adjustable hanging planters. Now we can easily reposition them based on our every whim!
Here is a vine of it:
Step 1: Mounting Hardware
This is where the generous kind and all around cool facilities folks - the ones you have to ask if you want to, say, drill holes in your nice fancy new building, come in.  Not only was Kevin cool with it,  but Ryan and Cornelle actually mounted the 80/20 for us.
So: mount a rail of 80/20, or anything sufficient to carry the load, above where you want your planters. This is where you'll mount your pulleys. Set them up so each horizontal planter has:
1 pulley for each side
1 extra pulley on the side on which you plan to place your counterweight. This will become clearer in the next step....
You can use any pulley that will carry the load - but probably cheap pulleys, that add some friction, will work best. You want the planter to be able to move up and down, but not without friction. A nearly friction-free pulley would force you to adjust the counterweight whenever you changed the weight of the planter (i.e. after watering the plants). Some friction makes thing moveable, but not too easily, so they won't move on their own.
Step 2: Setup Your Lines and Pulleys
We used some rectangular plastic planters, about 8 inches deep, 2 feet long. But anything will do as long as it can support itself when suspended by nylon cord.  We drilled one hole in each corner and threaded each of two nylon cords through. One cord entered a front facing corner, went the entire distance length-wise under the lip of the container, and then emerged from the opposite front facing corner hole. We did the same for a cord through the rear corners (see images). This makes it pretty easy to adjust the tilt of the planter just by grabbing it and tilting it, as the supporting cord can move freely through the holes. But there's enough friction that it won't go out of adjustment on its own. This is nice because getting the lengths of each cord just right can be tricky while holding a full planter.
You should now have a planter with two nylon cords supporting it. Thread these through your pulleys above as per the illustration.
The strings coming from the side of the planter farthest from the counterweight go up to the far side pulley, across the ceiling to a near side pulley, and then down to the counterweight. The near side strings go up to their own pulley, and then directly down to the counterweight. (see illustration). Once threaded, use some binder clips to clip the strings on each side together about a foot above the planter, so they are close together from there one up, and therefore less likely to slide off the pulley wheel.
Step 3: Insert Plants
We are lazy, and wanted to build in a water reservoir so we wouldn't have to water all that often. So we lined the bottom of our planter with styrofoam packing chips a couple inches deep, and covered over that with weed cloth. Then we put some dirt and plants on top.
Step 4: Counterweight And..... Hoist Away!
Now that your support lines are threaded, and your plants are inserted, you need to make a counterweight. We used a bucket of sand, but anything approximately the weight of your filled (and watered!) planter should do. The nice thing about a bucket of sand is that it's easily adjustable weight wise.
Tie your nylon string to your bucket, and voila! (add or remove sand as necessary).
Random aside:
If this were a piece of software, someone would have patented "bucket of sand used as counterweight" years ago, and you'd have to pay them a royalty to use their amazingly prescient idea (even if they never actually made a bucket of sand!!). But in this case, you are free to use (and even remix!) "bucket of sand" however you wish! w00t! Revel in this great freedom!
Step 5: That's It! (Room for Improvement?)
Hot damn! You can now raise and lower your plants to your heart's content!
Room for improvement:
1. Ours doesn't horizontally offset the counterweight from the planter. It'd be nice to have another pulley, maybe 9 inches to the left of the leftmost pulley, through which to run the lines going down to the counterweight. That way the counterweight would be suspended a bit further away from the planter. I think it'd look cooler, and the counterweight wouldn't hit the planter when they pass by one another.
2. Skip the pulleys - maybe thicker nylon cord could slide through a metal eyehook a bit more smoothly, making the pulleys unnecessarily? Dunno - hope somebody tries it.
3. Find a way to tap into your plant's desires, and, when the plants reach consensus that movement is in order, allow them to raise or lower the planter with an electric motor to suit.
4.... or maybe hook up one of those soil dryness testers, and make the planter get lower and lower the drier the soil gets? (And hoist itself back up after it gets watered?) That way the plant brings itself near to you when it needs some attention.... gnarly.
Things and problems with which we fought valiantly: (Because, hey, whenever you build something, it never really comes together the way you initially planned, even if it ends up coming together even cooler than that.)
1. Pulleys - We first got some lame ones from the home despot that had a lot of room between the pulley wheel and frame. The cord could pop off the wheel and then get sucked down into the axle in all the space. Some cheaper smaller ones, mounted on swivels, turned out to be a better solution.
2. Cordage - have plenty of it on hand, rated well above the weight of your planter and counterweight.  Otherwise, you end up trying to splice / knot pieces together and it doesn't look as good. It's also kind of hard to tie things while simultaneously holding 25 lbs of plant in the air.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    You have just given a great Idea for something similar I was trying to do :). Thank you so much. And those plants are pothos having dark foliage, you may not want to expose them to sunlight a lot, they tend to loose their color.
    This looks beautiful
    Awesome!! So happy this idea helps inspire other ones.
    And thanks for the advice! There are bars outside of the window that folks say block about 50% of the light, so it's not as bright as it would be otherwise. But perhaps I will lower the shade more often, to keep them from getting too much sun. Do let me know when your idea gets born - I'd love to see it!
