Step 8Computer Set Up
Hold left and right buttons down at the same time to reset,
the whole display will flash then go to the wheel size.
It will show 2124 the default setting with the 4 flashing.
Change the 4 to a 3 by pressing the right button.
Once it is at 3 press the left button to move the
cursor over to the next number and set it to 3.
Repeat until the number is 3333
It will then go to the KM/Miles mode.
Since it comes up as KM first just press the
left button to set it as that. The right button
will switch it back and forth between the two.
You set the time by holding the left button down for
about 4 sec when the display is showing the time.
You can select 12 or 24 hr mode then you
will set the time, hours and minutes.
If You you mess up just reset by holding both buttons for
a few seconds and start over.
How it works.
Say you want it to read 60KM at 60 RPM's
60km is 1km per minute or 1000 meters.
1000 meters is 1000/60 or 16.666 meters per sec.
Since there are 5 magnets for each rotation 16.666/5
is 3.333 meters per 1/5 second or 3333 MM.
Each time a magnet passes the sensor it is recording
as if it is moving 3.333 meters.
Mountain bikes or comfort bikes with 4 magnets.
16.666/4 would be a setting of 4166
The reason you need this many magnets is that the max
wheel size you can input on this computer is 5999.
I hardly ever have a Cadence above 90 so the 99 limit is
fine for me. You can cut the number in half and
remember to double the readout if you like. That will
set the top limit to 199.8 RPM's
To check your work go to this site and print out
a gear ratio chart using your tire size, front
chain ring, rear cassette size and the cadence
you want. You can cut it out and tape it
on your bike if you like.
http://www.sheldonbrown.com/gears/
Hope you enjoy this project as much as I do.
Oh, and something else - if you want to have a heart rate monitor too, than your handle bar will look more like the Maltese Falcon dashboard'Maltese Falcon' dashboard
But I really like your "not in a box" style thinking.
P.S. I am not an expert, but I've heard that 90rpms is recommended speed for normal ride, about 100rpms is for sprints and uphills and 80rpms is when you want your legs to rest (at downhill or flat).
P.S. Sorry, can't help but being "Monk'ish" a bit. In the last step the units are a little confusing, the speed is measured in km/h or m/s. I'm sure You know what I mean ;')
