Very Easy to Do Dolls Table or Desk
163
Published
Introduction: Very Easy to Do Dolls Table or Desk
About: Broken devices always have several useful parts,recovering them , we reduce trash ,then we are taking care of the planet
Having a 10mm mdf piece around I decided to make a table dolls by means of the " gardener's elipsis"
Step 1: Defining the Axis and Focus of the Elipsis
In order to maximize the exploitation of the mdf,after marking both central axis I left 3 cm on both sides of the longer axis,the outer sides will be the legs and the inner will be the top of the table
Step 2: Defining the Focus
Take the half of length of mayor axis,transport this length to the point of crossing of minor axis and upper side,and the mayor axis,this point is one focus,procedure the same way to the other side and you get the other focus
Step 3: Drawing the Elipsis
Pinch a pin on each focus ,then with a tanza or thread unite the upper point and the focus,this constant length will let us to draw the elipse,as seen in pictures
Step 4: Time to Cut
Usin a jig saw cut the elipsis, and then you get the top and the legs of the table
Step 5: Fitting the Legs
Make grooves on both legs in order to fit each other
Step 6: Fixing Legs on Top
Mark the place the legs will go,with a 5mm drill bit make 5mm deep groove,with the chisel complete the groove,make it a little smaller than the leg so it fits tigth
Step 7: Fixing Legs As a Desk
Get 4 pins,whit a file or grinder reduce its head in order to let introduce it in the groove,then fix the legs on the new way as a desk
    • Oil Contest
      Oil Contest
    • Pets Challenge
      Pets Challenge
