Very Efficient But Crude DC Power Supply :)
Introduction: Very Efficient But Crude DC Power Supply :)
Hello makers !
Today i just build this small power supply, today morning i was getting bored :/ and I wanted to build something. Suddenly i realized that, i have one 12-0-12 transformer and a pair of buck-boost converter laying inside my drawer and, there i got an idea to build a simple dc power supply from it. It is kind of crude build but it can power your projects very efficiently and it will not take a lot of space.
Step 1: Bill of Componets
1. Transformer: 12Vdc, at least 2amps for good performance( center-tap is not necessary)
2. Rectifier: 4x 1N4007 diodes for bridge rectifier or bridge rectifier IC with 2amps rating.
3. Capacitor: 220uF, 50v (I used 1000uF ,35V because that was onl available with me )
4. Switch: A2-way switch.
5. Buck-converter: LM2596S module
6. Boost-converter: XL6009 module
(they r many more buck-boost modules available u may choose according to your need)
7. Binding posts: output connectors.
8. Enclosure: a plastic box prefferably
9. power cord: a wire with plug attached for transformer's input.
Tools used are.....
soldering iron , wire stripper, glue gun.
Step 2: Diagram, Connections and Why I Didn't Use 78xx Linear Regulator If You Are Wondering :p
connections are simple as shown above in the diagram. i didn't use center tap, but i used the end wires to get 24 volts ac. then i used rectifying I.C to convert ac to dc.I used I.C because I salvaged it from an old PCB so i need not take trouble to solder four diodes to make bridge. the rectifier output is pulsating dc and we need to convert it to a smooth dc voltage. this is done by the capacitor connected in parallel. 220uF capacitor is enough but, u need to take care of voltage rating since the capacitor charges to peak voltage of pulsating ac. mine is 25V ac which will charge capacitor to 32V dc peak so i used 35V rated capacitor. the i connected it to a 2 way switch which i used to switch between buck converter and boost converter. and the output is given to 3 binding post,connectors one of which is common ground.
Now the biggest question " Why the heck i used this fancy thing called buck-boost converters?!"
well this is for those who didn't use them... if u know what i m talking about proceed to next step :)
there are many makers use ICs like 7805 or 7812 or 317T , these are actually called linear regulators. they actually regulate dc to give constant set output. but they are very inefficient as they drop out "extra" voltage and waste energy. for eg; if u give 10V to 7805 it will give 5V output but it will dropout extra voltage across its internal resistor which leads to lot of energy wastage.therefore you loose more and more power as heat as u draw more current so we use that big heat sink to protect it from itself. so this method is out of time now. u can do better use of them y using them as voltage reference in your projects.
now look at the buck boost converters. they are kind of switching mode supply which store energy and use them efficiently. for more info, google it there is lot to learn about them. for comparison, these r like 80% to 92% efficient then conventional linear regulators.
now u understood the concept everything is easy now.
Step 3: Prepare Your Enclosure.
Now take the box and make holes in it to put connectors and wires. use drill if u want but i used soldering iron hot tip to get things done fast. attach switch, binding post and make a small hole to insert wires.
Step 4: Prepare Regulators.
Desolder the potentiometers from both the modules and extend them using some wires, so that we can arrange them according to our convenience. remember the orientation of the pots while soldering.
Step 5: Soldering Everything Together
Now solder everything together according to the diagram. after soldering insulate joints with insulation tape. fix everything with a glue inside the box. I used glue gun to stick everything in the box and also insulate some hard to reach joints. i also fixed both voltage variable pots to the top lid for easy access.
Step 6: Finishing Evrything !
finally close the box and label everything. you r done :)
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Simple but effectivce, sometimes that's all you need. ☺
    yes.. I build it so i can mount it in my study table as my ATX power supply for to large near my books ;)
    Nice project. You do know that you could run both the buck and boost at the same time instead of using a switch. And one other thing I need to mention. When building any electronic circuit, especially a power supply, always use parts that are capable of more then the requirements you are build towards. For example, You are building a power supply and used a 2 amp transformer. But you stated that you need 1N4007 diodes to make a bridge, or any bride for 2 amps. If you draw even slight over 2 amps, guess what will eventually happen to 2 amp diodes or bridge? And 1N4007 diodes are rated at 1000 volts 1 amp. Always, and I mean always use parts that exceed the requirement if you want it to last for more then a few months. For that bridge, a 5 amp or even a 10 amp bridge will work better. Same with the caps. If your power supply is going to output 32 volts, don't use a 35 volt cap. Use at least a 50 volt cap or higher working voltage type. That way you exceeded the capability and have protection IF you get some spiking. Other then that, nice idea and design.
    thanks buddy for mentioning this :) Yes we need to use parts which r rated well above the maximum requirements. I actually build this very fast like it took me 45 mins for whole build from gathering components to full build. i actually build it from the spare parts which i had. so i used that bridge rectifier IC. Actaully the output of transformer is 32V peak to peak. soif u use say 1N4007 diodes for rectification in bridge configuration then, 2diodes will be active at a time during each half of ac. so say if i want less voltage at the output of buck converter say 10 v and i am drawing say 1 amp then it is 10 w at the output but the output of transformer will little more then 10 Watt (because of non ideal conditions) then also i will be drawing 0.4 amps. so diodes will handle it. but u r true if i am drawing 1amp @ 32 volts i.e 32 watts from transformer then i will high rated diodes.
    yes and i completely agree with u when it comes to capacitor.i really used the 1000uF 35volts cap which can eventually leak due to dielectric rupture as my 32volts output is very close to 35 V limit of cap.
    also i can use booth regulators at the same time and i dint need switch but i used it to protect those switching mode supply, because if no load is connected to any switching mode supply n it is on it gets damage due to its internal frequency. yes better option is use two switches for both but my box was too small so it was hard to find space for second switch :P
    thanks for pointing out mistakes because, I should have mentioned this while writing instructable.
