Very Simple DIY Table Saw
45,057
163
15
Posted
Introduction: Very Simple DIY Table Saw
This homemade table saw is made out of a track saw
Step 1: The Idea
a track saw has a rail
but if you turn the saw upside down
the rail becomes a very handy cross cut sled
Step 2: What Can You Expect?
with a special clamp , that fits into the rail
you have a very clever crosscut sled
you can cut every angle you want
and with a board, as a table saw fence, you can cut all of your stripes
for bigger parts, you can easily uninstall the saw
and use it as a normal track saw again
Step 3: Overview
you need only to build
  • a jig for the deep setting,
  • a frame for the saw and
  • a trigger for the switch
Step 4: How to Built the Frame
The frame is made out of two boards
in the first picture, you see a little nose on the saw
this nose disturb the fit of the boards
so I cut them out with a jig saw
Step 5: Set Up
I screwed down one board on my table,
I placed the saw in position
and then I screwed down the second board
Step 6: Secure the Saw
this saw has two holes on his plate
but unfortunately this holes are out of the range of the boards
so I screwed two blocks of plywood under the boards
and I could fix the saw with two screws
Step 7: Prevent the Rail for Tillting
This rail has a second slot on the back
I used this to secure it in place
I drilled two holes, threaded them and screwed to bolts in
Step 8: The Trigger
a little clamp, made out of 6 mm Plywood
hold the switch in place
for work with the saw you need an outlet with a switch
Step 9: The Deep Adjustment, Step 1
My saw has a hole in the handle
in this hole fits perfect a 6 mm threaded rod
Step 10: The Deep Adjustment, Step 2
this threaded rod goes through a slot of a little board
made out of 4 mm plywood
Step 11: The Deep Adjustment, Step 3
to screw on this board, it was necessary to drill and thread a new hole
first I thought, I can use the existed hole above
but this is to high, and it disturbs the saw to tilt it to 45 degrees
Step 12: Supporting Boards
my rail is 12 mm high
therefore I screwed two 6 mm boards of MDF on the left side
and two of them, glued together, on the right side
but on the right side, I made a cut with the saw so
the saw blade and the riving knife comes all the way through
Step 13: The Result
Instead of thousand words, please watch the video
If you use a mobile device, use this link .
If you want to see more of my work, subscribe to my Youtube channel
  • Sew Warm Contest 2018
  • Gluten Free Challenge
15 Comments
Could you add a paper template for the depth adjustment and the
"always-on" clamp? That would be very useful, and you just have to trace
your existing parts on paper and scan them with some scale added.
Nebenbei: Grüße aus Innsbruck und besten Dank für die Idee!
ok :)
Schöne Grüße aus dem Waldviertel!
Step 1: Get a festool tracksaw
Step 2: Oh wait, I can almost get a table saw for the price!
Speaking more seriously this is a good example of working with what you have, I have improvised with hand tools as well. Maybe not the safest or right application, but if it does the job and doesn't pose an almost guaranteed danger - why not.
Bring your DIY's to INSTRUTABLES.Raitis !
We are waiting.
If you can get a table saw for the price, than you have a toy, I guess.
And if you think Dewalt or Makita is cheaper, look at the picture.
Ahh, I looked into some different model of this same look which goes for almost 800 euro where I live (new). But really, the point was what rustybender wrote. I wasn't trying to mock what you made in any way, sorry if it looked that way.
In the US you can find used contractor saws on Craigslist and at pawn shops for under $400 easily. I would hardly call those toys. They aren't cabinet saw quality, but they are going to be better suited for table saw work than any upside-down track saw. I think Raitis's point is it would be foolish to go out and buy a track saw just to use in this manner. Now if someone already has a track saw, this is a clever way to repurpose that tool and delay purchasing a dedicated table saw. It would also be a nice alternative for someone with limited workshop space.
I have a table that converts a circular saw into a table saw. It also has mounts for a router and jigsaw. It's a plastic piece of crap but I got it at a garage sale cheap.
its interesting but I question the safety. Go to Harbor Freight or Big Box for a purpose built table saw, your fingers will thank you.
Do you have any specific issues in mind?
