Very simple and cheap Guitar/Bass distortion pedal
  • last photo ←
Here, I will teach you how to make a very simple 1 transistor low power guitar pedal. (I designed the circuit diagram and PCB). This circuit can be ran off old 9v batteries (In version 2, I was running it off a really cheap mobile phone power supply, 5v SMPS) that still have a charge above 1.5v meaning you won't have to throw them out!
Edit: If you increase the input capacito (the 100n capacitor) more bass frequencies can flow through the common emitter amplifier, causing more of the distorted effect.
Also, if you change the bias of the transistor (swap the 100k Resistor for a much higher value, e.g. 680k or more, the transistor will be forced to asymmetrically clip, increasing the distortion. Go to the last page for sound clips :)
In my new circuit, I use a 470k resistor for the bias resistor.
AGAIN! A problem arises at the cost of extra distortion. The attack of the
instrument may get chopped off (silenced in this case). With my bass, this only seems to happen when I am using the slap bass technique.
Step 1Find the parts!
Find the parts!
Firstly, to make the pedal you obviously need the parts! Most of the parts can be found in the base of a CFL light bulb. I already had the parts to make this and have customised the parts to my liking. In the schematic, it says the input capacitor is 100n. It doesn't matter what value the input capacitor is really aslong as it is within the range of: 47n - 100uF. All the capacitors mainly do is affect the level of distortion at the output (as well as the diodes at the output!). For my transistor, I used a BC337 (On my old one) because I had it at the time but I'm sure that any NPN transistor will work fine. At the output stage, different kinds of diodes produce different levels of distortion. I used simple 1N4001 diodes (The most common diode around) But to get different kinds of output waves, many combinations of diodes exist such as schottky diodes (To produce a lower amplitude giving a nice germanium diode sound due to both germanium and schottky conducting at lower voltages) or rectifier and schottky diodes (Lopsided wave) etc. I tested the input down to 1.5v. at this voltage, it had some quite high distortion and a bit of an annoying hum but worked fine overall. Therefore, a 9v battery would last extremely long is the circuit works down to 1.5v.
The input and output capacitors depict the frequency response of the circuit e.g. The lower the input capacitor, the more bass is cut. This is good if your looking for a nice Trebly overdrive. Otherwise, this capacitor can be increased to any value. The values of these components doesn't particularly matter if your just looking for a simple distortion circuit.
The 100Ohm Resistor that is just above the Diodes can be removed to make the output wave much 'Harsher'.
The 100K resistor at the base of the Transistor mainly depicts the gain. Increasing this resistor increases the gain up to a certain point (It changed the bias of the transistor).
Edit: I have now included my new circuit diagram for the much more RAW! Distortion. Go to the last page for sound samples! Unfortunately, with this new circuit, the distortion isnt so epic at 1.5v :(
For this new circuit, i used a BC337-25, a much more gainier transistor.
101 comments
1-40 of 101next »
Jan 1, 2012. 6:55 PMSam i am561828 says:
sorry to bother you again.
i made it shown in the schematic but still got nothing but a loud buzz/hum sound.
all the resistors were bought new. The transistor, diodes and the black capacitor were all from a dead CFL Light bulb. The 10µf capacitor i found lying round the house.
Can you please please please have a look at my picture to see where i may have gone wrong. (the positive terminal of the battery may look like it is connected to the diodes but it's not, just the bad angle of my camera)
Dec 28, 2011. 6:09 PMSam i am561828 says:
hi, im new to all this so i have two question to start with
1st: If the CFl light bulb is dead, will the components still work?
and 2nd: can i use a 1000uf polarized capacitor as the input cap?
thanks in advance
Aug 30, 2011. 1:47 PMdyanakiev says:
Hey there! First thanks for sharing this with us! And second i have a question for you. I have done all that is on the schematic the first one, the source i use is 12V . Well i have double checked everything i connected and all i get is a clean bass with no dist. I have been reading the comment here i havent found the answer i have been searching for. I have been wondering if i connected the 10 mikroF cap correctly : i connected the + of the cap from the colector side. I think this is right because that is the direction of the current, right? If that is not right i don't have any other ideas why wouldn't i get no dist. Its like i have connected the the two female jack's directly.
Sep 15, 2011. 4:06 AMdyanakiev says:
Hah sorry to have bothered you seems like the dist was so little at first with th 100kohm resistor so i couldn't hear it. I added 3 more and made i 400kohm. Now i surely can hear it :P . Thanks a lot!
Aug 25, 2011. 1:25 PMVenomousFish. says:
Sorry to ask this, but I don't know much about reading schematics. Where is the negative connection for the power supply?
Sep 12, 2011. 1:40 PMPJEC says:
Maybe this is a stupid question (sorry if this is the case), but where's the pedal?
Apr 24, 2011. 9:46 AMThereyouhaveit says:
Erm , i did what was shown on the schematic and it didn't go well ... it was a chopped up distorted signal .
Apr 10, 2011. 6:07 AMThereyouhaveit says:
I have no clue why would you want to tie the collector to the output o.o
Dec 2, 2010. 11:54 AMnikolai850 says:
is the the circle with the sine wave in it supposed to be a light emitting diode?
Jan 15, 2011. 10:24 AMoweng4000 says:
Nope, that's your guitar.
Jan 21, 2011. 6:53 AMoweng4000 says:
Cheers Pyrohaz!
Nov 12, 2010. 8:55 AMNight910 says:
If I get parts from a CFL, about how much would this project cost? Also, is there a way to make it a fuzz pedal instead of distortion?
Oct 6, 2010. 1:24 PMvirajprabhu says:
how did you make that guitar file you have recorded last????? as i wanted to know exactly what modifications you didi to make that,,,, pls let me know sir.....
Nov 3, 2010. 8:48 AMvirajprabhu says:
hey i conneced the circuit in the same way but i am not getting any output.... i tried connecting the input and output directly without the circuit and i got output... but not with the circuit.... there is no problem with the components and the wires and amp...... ia there anyhting that i may have overlooked and i am not getting output.... pls reply.....
Aug 16, 2010. 5:49 AMthe rhytym says:
iwant to specipy the polarity of each components because i dont now were is the polarity
Aug 9, 2010. 7:23 PMgrade says:
hello... :) i have a little confusion about the diagram, i want to clarify that portion above the two connected diodes that has a label 100. thanks...
Apr 11, 2010. 3:34 PMgrantloughran says:
is ther anything i can add to make it mor distorted?
thanks
Jun 5, 2010. 12:23 PMdavidpaul23 says:
1. Where do i place the volume and distortion pots in the schematics dude...? 2. Is that at the input before 100nF...?
May 15, 2010. 4:39 AManiket chaphalkar says:
 hey thanx man... this would be my 1st time 2 make a distortn n u ve the most easy way 2 build 1. thanx
Feb 4, 2010. 5:45 PMsmithman99 says:
where can i get these plain circuit boards?
Dec 21, 2009. 12:37 PMdanymw says:
where do you put the + and - of the battery?
Dec 22, 2009. 8:49 AMdanymw says:
I mean the schematic but I connected the - from battery to 0v. My board is complete now but I can barely hear any difference between the clean sound of guitar and distortion on. It's 100% correct unless there is a part (apart a wire) above the 2 diodes. (there's something? 100 near 2 bars,above the 2 diodes)
Thanks anyway,I'll try to put some heavy distortion.
Dec 1, 2009. 7:51 AMampblaster says:
I'm just a beginner, but I know enough to feel like I'm confusing myself by looking at these diagrams.  Since there was never an actual step by step for connecting everything, where could I find instructions on the general construction of each part?  I literally can't tell what the hell I'm looking at in these pictures, either due to blurriness, or wires stacked on top of each other in perspective.
The schematic doesn't seem to help me either, as it doesn't seem to coincide with the pictures of your final product.  Do you have any "noobed down" steps that I can look at just to get started?  All I have in the breadboard at this moment is the input jack (where's the output jack, can I use one?) and the transistor, which in my case isn't even the same transistor.
Also, what's the difference between using an op amp and transistor in this pedal?  How much does it change the wiring because of the pins?  I have JRC4558D chips lying around, and thought I may be able to kind of mock a tube screamer with the same diodes and op amp.  Thoughts or suggestions?
Thanks for any help you could give.  It's a lot of fun for how frustrating it all can be.
Dec 6, 2009. 6:46 AMampblaster says:
Hey, I've tried a few different overdrive instructables on the site, and unfortunately, I just can't get seem to get them to work.  When I use a multimeter I get various levels of voltage through areas, but then it tends to drown off at the parts that aren't so clearly connected in the schematics.
When you get time, can you explicitly explain the process of what gets connected to what and how.  Like literally physically connected?  I'm incredibly confused at why there is only     one      1/4" mono jack.  How do you take the circuit from that jack to make sure it goes to another jack?  Obviously my reason for wanting to do this would be to have a seperate input and output for the guitar>pedal>amplifier.
Sorry to ask so many questions.  Thanks for your time.
Dec 1, 2009. 7:01 PMampblaster says:
That's about as much as I could hope for you to do.  MUCH appreciated information, and I'll brush back up on my math so I can fool around with my own combinations.  That definitely leads me in the right direction.
Thanks for taking the time to answer.
Dec 1, 2009. 7:58 AMampblaster says:
Sorry, but on another note, I realized the jack is for the OUTPUT not INPUT.  But this just basically reverses my question.  Coming from an electronics beg. who is used to seeing his guitar pedals all boxed up, I'm so confused about what actually ends up powering what and how you use it with guitar cables.
Oct 1, 2009. 6:34 PMMrRodrigez says:
hey, you think it would pay off to put in another circuit that has the same layout, but different config and a DPDT switch to have 2 different drives? I was thinking that would be pretty cool, but idk how much work would be involved..
1-40 of 101next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:pyrohaz
I'm a student from Cheshire, hoping to study Audio Electronics. I play bass and enjoy listening to music :)
