Support DIY and Instructables : Become a Pro Member Today!
Very simple and cheap Guitar/Bass distortion pedal
intro
introVery simple and cheap Guitar/Bass distortion pedal
Here, I will teach you how to make a very simple 1 transistor low power guitar pedal. (I designed the circuit diagram and PCB). This circuit can be ran off old 9v batteries (In version 2, I was running it off a really cheap mobile phone power supply, 5v SMPS) that still have a charge above 1.5v meaning you won't have to throw them out!
Labelled breadboard.pngOD.jpgOverdrive PCB.pngIMAGE_003.jpgIMAGE_001.jpgIMAGE_004.jpg
To View All Steps on one page,
Go Pro Today!
step 1Find the parts!
Firstly, to make the pedal you obviously need the parts! Most of the parts can be found in the base of a CFL light bulb. I already had the parts to make this and have custo…
step 2Build the product
I build this on a breadboard as i have not had time to produce the PCB yet. The parts for this pedal are really cheap (around 50p if postage doesn't have to be paid) and ca…
step 3Final product
Here's what my final product looked like! (Sorry for the blurry picture, I had to take it on my phone)
step 4What both versions sound like
Here is an sound file of how my overdrive pedal sounds. The first riff is clean and the second riff is the same as first just distorted. Thanks for reading!Revised sounds:T…
62 comments
1-50 of 62
Oct 1, 2009. 6:34 PMMrRodrigez says:
hey, you think it would pay off to put in another circuit that has the same layout, but different config and a DPDT switch to have 2 different drives? I was thinking that would be pretty cool, but idk how much work would be involved..
Oct 4, 2009. 6:10 PMMrRodrigez says:
sweet, ill try that after i get the time to finish the first one lol
Aug 16, 2009. 12:15 PMmikehayworth says:
(removed by author or community request)
Aug 4, 2009. 9:22 AMhogge says:
could I use a resistor with lower value instead of the 100k resistor after the input capacitor?
Aug 4, 2009. 12:54 PMhogge says:
i have one that is 400 something ohm
Aug 4, 2009. 1:16 PMhogge says:
doh but thanks for a simple dist
Jul 20, 2009. 1:17 AMking7pin7 says:
Hey, do you have any good instructions on how to hook up the instrument input and the instrument output?
Jul 8, 2009. 11:37 AMCole.Dickson says:
lol made it again didnt work, man this thing is giving me trouble. Can i use a 3904 transistor? and does it matter what kind of diodes i use ? i know the diodes effect the distortion but will it work with any diodes? How exactly do i ground the circuit. sorry im such a nub
Jul 8, 2009. 1:24 PMCole.Dickson says:
Im using a 2n3904 transistor. 2 diodes i found off an old tv but i dont know what kind they are I only know the polarity of them. 10uf cap for input and 22uf cap for output and a 10ohm and a 100ohm resistor. and im using a 9v battery with 5 volts of charge left. Im going to try and breadboard it again and then ill upload a pic i still cant get it to freaken work . Im sure im doing something wrong,
Jul 8, 2009. 2:37 PMCole.Dickson says:
Hey could you give me some feedback. I just noticed the battery isnt in the same slot but i moved the wire and it still didnt work. All it does is hum and i know thats partly cuz i didnt ground it yet but i cant get the guitar to sound at all.
Jul 8, 2009. 5:14 PMCole.Dickson says:
lol im getting so frustrated i just cant friggen make it work
Jul 11, 2009. 12:44 AMCole.Dickson says:
wow thx for doing so much for me. I finally made it and i works but it has a huge hum. I dont think its properly grounded cuz when i touch the guitar or the components the hum changes.
Jul 11, 2009. 11:59 AMCole.Dickson says:
im using a 9v battery with 2.2 v left.
Jul 11, 2009. 12:19 PMCole.Dickson says:
i followed the breadboard pic exact;ly. i can hear the bass but its not distorted at all and the hum is super loud even when i switched to a ac-dc power supply.
Jul 11, 2009. 1:09 PMCole.Dickson says:
maybe its the components because even without the diodes AND the power supply it still hums.
Jul 11, 2009. 2:10 PMCole.Dickson says:
grrrr i give up
Jul 11, 2009. 3:42 PMCole.Dickson says:
i found out if i cover the jacks with my hands the humming gets way quieter. any ideas?
Jul 11, 2009. 4:14 PMCole.Dickson says:
i just cant figure out what is making the hum. The power supply seems to make no difference in the circuit. What is it supposed to do in a working one?
Jul 11, 2009. 9:08 PMCole.Dickson says:
ill try that but why doesnt the power supply do anything in my circuit?
Jul 7, 2009. 9:19 PMCole.Dickson says:
thx so much man this helps
Jun 26, 2009. 5:39 PMCole.Dickson says:
hi i tried breadboarding this but all i got was a loud feedback. Could someone please upload a better photo
Jun 26, 2009. 5:43 AMUnreal X says:
ok so..i build the entire thing on a breadboard hooked up to a powerbox and all i hear is a sound rilly high pitched and then it turns into a sond of a ping pong bal droping
Jun 26, 2009. 10:09 AMUnreal X says:
i had everything right but maybe the capacitors were backwards or sumn i made it 4 times and it still doesnt wurj btw should the cathod or anode end go to the posative
Jun 25, 2009. 9:02 AMfrag_bomb says:
I just finished mine sounds awesome i changed the cap for a 47uf now im getting a heaver sound, thanks man
Jun 22, 2009. 4:11 PMgomalopa says:
i only have a LM D2583 NPN transistor, do you think that may work? (Sorry for my bad English)
http://pdf1.alldatasheet.com/datasheet-pdf/view/209040/TEL/2SD2583.html
Jun 24, 2009. 1:57 PMgomalopa says:
hi, thanks for the reply, i have another question: what is that beside the diodes? a potentiometer? (only says 100)
Thanks
Jun 23, 2009. 10:34 AMUnreal X says:
does it have to be a plessey capacitor or will any 47uf capacitor work
Jun 23, 2009. 8:43 AMUnreal X says:
hey do u think coud maybe add a clerer picture
1-50 of 62
Related
