Step 7Remove the Vespa glovebox
First you need access to the area behind the glove compartment. Other projects have show this before so I will go quickly through it.
1. Carefully pop off the Piaggio emblem off the front of the horn cover (I actually broke mine so I suggest you do it very carefully).
2. Remove the screw holding on the Horn cover and then remove the horn cover.
3. Remove the two screws behind the horn cover. Then open the glove box and remove three screws inside.
4. Now carefully remove the glove box panel. You will have to hold the latch down to get it past the ignition mechanism.
5. Now there is a fuse box that lives in the space behind the left knee pad. I popped that off it's mount and fed it through the opening to free the glove box panel from the rest of the scooter.
Add Comment
