Remove these ads by
Signing UpStep 1Open the run window
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
OR
START KEY+R
then you will see two groups the Explorer and System
-Go to Explorer you will see several Registry Data at your right pane
-Find "NoRun" right click modify (The Current Value of NoRun is 1 change it to 0)
-Run Command in Start Menu is now enable
-Or you can also use the TaskManager but if TaskManager is also disabled
procedure but you will go to System instead of Explorer
Find "DisableTaskmgr" change value to 0
I hope it help :))
If so,there are plenty of tools can complete the task,for instance,windows password rescuer,NTpassword,windows password Ophcrack.
@echo off
command.com
@echo on
save it as command.bat but make sure you save it as all files and save it to your desktop click it and you have a working cmd (psst im 11)
ues
http://www.instructables.com/id/Unblock-CMD-at-school-and-become-the-administrator/
