This instructable has been removed by the author.
19
comments
Add Comment
Warning:
If you don't do this right, you will get CD fragments in your victim's drive. So make sure you do a good clean job cutting and sanding the CD.
A drive could also get damaged if it is being "vibrated" for a long period of time, but most people turn their computer off as soon as they get pranked.
First, CD drives are not designed to spin unbalanced loads that is why most CD's are round. There are several non circular CD's, like business card CD's, but even business card CD's are balanced to prevent excessive axial loads on the motor.
Excessive axial loads can cause the shaft to bend slightly or spin off axis. Off-axis rotation puts more force on the bearings and the other components internal to the drive's motor, possibly causing those components to fail prematurely. Additionally, the tolerances within the motor can decrease to the point where they rub against one another increasing the heat and damaging the drive.
Second, the CD itself will be subjected to vibrations and stresses not designed for. If ripples caused by off-axis rotation become significant they can scratch the laser's lens, damage the tray, or circuit boards. If the CD isn't strong enough to deal with the stresses, it will simply fall to pieces in the drive.
Best case, you've annoyed someone and decreased the life of the drive. Worst case, you've severely annoyed someone and destroyed the drive.
Thief II cd 2 RIP.. the motor was ripped out its housing and the cd was shattered in the drive.. a total gonner..
I briefly skimmed this link, it seems to describe what I'm worried about pretty well: http://www.mscience.com/faq17.html
It seems that you can easily permanently damage the drive, and also this may cause the CD to shatter which could also permanently damage the drive.
I can't see this being good for the drive, nor safe for the hard drive.
There's more creative and safe ways to prank your friends.
