Vibrobot from old camera
Inspired by the large bristle bot and Evil Mad Scientist (I'm having something of a crush on them lately) I decided to build a vibrobot. I used parts from a camera and some tape, less then a dollars worth total in my case. It's not terribly detailed and since the specific camera isn't likely to be found, it's more of an inspirational writeup of what one might do with scraps.
WARNING WARNING WARNING WARNING WARNING WARNING
Cameras with a flash contain a capacitor that may be charged even after the batteries are removed. Touching it's leads may discharge it into you, i.e. shock you. Opinions differ on how much actual danger is involved, but either way you do not want to touch it. There are a few other articles on instructables and elsewhere on how to safely discharge them (such as locating them and shorting them with an insulated screwdriver). Otherwise, disassemble while aware that some leads or components may have power in them despite the lack of battery.
Step 1Materials
Materials
As mentioned, I used an old camera. I bought this one at Goodwill for 75 cents. I wasn't specifically aiming to use it for this, but it did obviously have a motor in it (to advance the film), as well as clearly some other possibly useful parts (including two LCDs, some LEDs including an IR and some various other actuators). Clearly something to be used and this fine day when most people worry about the superbowl, I used it for this. I also used some duck tape (generic), perhaps six inches.
18 comments
May 24, 2008. 12:00 PMn8man says:
mine shocked me after I took the battery out. ???
Aug 2, 2010. 4:17 PMagis68 says:
You can connect a 10W 10 Ohm resistor to empty the capacitors...
Jul 25, 2010. 12:00 PMriverreaper says:
cool could that in sum way be hooked up to the screendoor handle to punch the friend you invite over as a gag ?
Jun 1, 2008. 9:28 AMn8man says:
Yea I figured that out a while ago but didn't feel like posting it.
Jul 21, 2008. 7:09 PMthe pro says:
before you take the battery out take a picture with the flash on (if you can) and quickly remove the battery so the capacitor will not be able to recharge. the capacitor will contain less (or no) charge.
Jul 26, 2010. 9:00 PMagis68 says:
you waste of a camera to do this???....
Aug 2, 2010. 4:16 PMagis68 says:
Now I agree with your job which is well done....I have the same camera and has a film processing problem (maybe a gear is damaged).
Jul 29, 2010. 8:27 AMcomputer_freak_8 says:
Off topic question: What model of keyboard is that in the background of your pictures?
Jul 31, 2010. 7:41 AMcomputer_freak_8 says:
Ah, okay. Yeah, I noticed the all-black keys, and I thought it looked Logitech-ish or Dell-ish. That would explain it. Cool Instructable by the way, but the keyboard is what really caught my attention; I've considered getting a Das Ultimate keyboard, just for the blank keycaps. Maybe I should get a Logitech and just mod it. That would make an awesome Instructable. (Hint, hint!)
Feb 16, 2008. 2:54 PMNaeem Iftikhar says:
I Wander really people having money and time to wast???
Feb 3, 2008. 12:08 PMKiteman says:
There was an LED in the camera? Wire it back into the bristlebot and you can enter it into the LED contest!
Feb 3, 2008. 10:48 AMGorillazMiko says:
Cool! Try making it circle around your cats if you can, it'll be funny, nice job. ;-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:LarrySDonald
