Vibrofoot - Silence Your Printer
5,520
126
6
Posted
Introduction: Vibrofoot - Silence Your Printer
I got really annoyed by the vibrations and noise I had to endure while printing.
Especially certain diagonal movement caused everything to mae noise.
Of course I tried the usual remedies you will find in printing forums, like an enclosure, cork disks between motor and mounts and so on.
But when I had to place my subwoofer to a different spot it hit me:
Stop the vibrations from spreading and causing noie the same like on the speaker system :)
So I quickly created a resting disk and cone foot for m printer, printed it 4 times and now all the vibrations are just gone - I can barely hear the printer in use.
Although I can not confirm this for other printers but I also noticed an improvement on the surface finnish of printed parts.
In my case this relates to the high print speeds (usually around the 80-100mm/s mark) and the spring loade mount for the build plate.
Rapid moves plus the vibrations caused "wobbly" lines in some areas.
Don't mind the betterprnts but the main goal was silence and this was done good :)
My printer is an old Prusa with the threaded rod frame so I desgined the parts to fit here.
But it should wok on any other printer the same way, just print the cone with good support if you need a flat surface or close the square hole for the printer feet at the bottom.
If in doubt just ask and I might even upload a different one to fit all by gluing or screwing them on.
Vibrofoot Bottom by Downunder35m on Sketchfab
This is the bottom disk, here the tip of the cone will rest in the center.
Vibrofoot Top by Downunder35m on Sketchfab
The tip of this cone rests on the above disk, causing massive pressure onto a tiny spot.
As a result noise and vibrtions can no be transfered that easy and the stuff is quite :)
Works great under speakers on wooden floors too, especially if you have someone living under you.
Usage:
Well, that's where it gets really complicated...
Take four and place under the corners of your printer, somewhere that offers support or under the original feet.
If in doubt add some glue or double sided tape to hold in place.
Rest the tip in the center of the disk and you are done.
No really! It is that simple!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
6 Comments
Can anyone confirm the vibrations transference reduction using this foot configuration? I might mill or a couple sets for other vibration reduction applications, like our washing machine.
Well, it's not the vibrations which are loud, by me propellers which are cooling extruder motor and electronics is quite loud.. (I have reprap i3)
I would either add resistor to make them slower or get one of the PC fan controller to add in-line.
Of course upgrading to better fan with less noise would help too.
Anyone tried it and likes to comment if it helped to slince you printer as good as mine?
What material did you print this out of? Ninja flex, ABS?
Nothing fancy, just plain PLA.
The harder the material, the better.
Was too lazy to make them from aluminium on the lathe but now I wonÄt bother anyway LOL
