loading
loading
Picture of Victorian Speakers
These are speakers I designed and made for my design technology class. See my design website here to look at my full research process:
The task for this unit is to design a set of designer speakers that will be specific to a certain client's needs, while exploring the appeal of designer products.
Brief: I will design a speaker for an audiophile who seeks maximum quality sound and a great design. It will be used at a home study and will radiate a cross between a victorian and modern look that is of high sound and material quality. For maximum sound quality and good design, it should be a set of stereo speakers inside one speaker enclosure, and easily portable and designed for laptop and smartphone use.
** Quick notes:
1) I'd advise you to read through all my steps before starting because being a novice, I mess up in a lot of places and I'll give you tips on how to avoid these messups in later steps.
2) I'm a student, so if you're very familiar with design, don't expect this tutorial to be to your level. I'm a novice, and I'm very unfamiliar with all the tools available. If you're in that position, then this is perfect for you. :)
Step 1: Draw out the final design to scale
Picture of Draw out the final design to scale
This is necessary to plan the measurements and materials needed.
Here's a picture of my design, and the second is the one with measurements (ignore the horns, they were too time-consuming and thus left out)
The material I decided to use was pine wood, which I will later on lacquer/ paint.
Step 2: Cut out the wood pieces
I gave my pieces of wood to our school technician to cut for me (is that what they're called?).
The wood I chose was pinewood, but from my research, MDF and plywood are supposed to be denser materials that will provide better acoustics.
Here are the dimensions:
2 pcs 100mm x 210 mm x 10mm
2 pcs 60mm x 70mm x 10mm
2 pcs 70mm x 190mm x 10mm
(I later trimmed down the 100mm x 210mm x 10mm pieces to 90mm x 200mm)
MattCP2 years ago
PVA...(Polyvinyl acetate) not PDA
MattCP2 years ago
That looks Great!
