3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Video Camera Mount for Bicycle
Step 4Pan and tilt.....
pan and tilt.....
I wanted to be able to fix the camera in different positions for different angles. Not live while riding the bike, but to setup different shots.
i had a bunch of ideas and eventually went with this one. in effect it gives pan and tilt. by rotating around and tightening against the horizontal rod (the one fixed to the bike) i can tilt the camera up and down then hold it in place, byb rotating around the shorter rod i can get tilt. I used a cute little aluminum block from some old optics kits i've got but you could make one of these easy. drill 1/2 in holes at 90 degrees to eachother in an aluminum block then drill and tap two fastening holes for bolts, one that enters into each hole.
this is the expensive version of these clamps but i'm sure you can see how to do a cheap version:
http://www.newport.com/Opto-Mechanics/1/productmain.aspx
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:saul
