Video Streaming Web Server
3,208
51
4
Posted
Introduction: Video Streaming Web Server
On my last tutorial, FROM DATA TO GRAPH. A WEB JOURNEY WITH FLASK AND SQLITE, we learned how to:
  • Capture real data (air temperature and relative humidity) using a DHT22 sensor;
  • Load those data on a local database, built with SQLite;
  • Create graphics with historical data using Matplotlib;
  • Display data with animated "gages", created with JustGage;
  • Make everything available online through a local web-server created with Python and Flask;
Now we will learn how to
  • Streaming a video,
  • Integrating the video on a Web Server.
Step 1: BoM - Bill of Material
  1. Raspberry Pi V3 - US$ 32.00
  2. Raspberry Pi 3 model B NoIR Night camera (*) - USD10.00
  3. DHT22 Temperature and Relative Humidity Sensor (**)- USD 9.95
  4. Resistor 4K7 ohm
(*) I used on this project a Night Camera, but a normal PiCam (or any USB camera) can be used.
(**) The DHT22 is optional. I will show how to integrate the Video Streaming to WE Page that shows historical data from sensors.
Step 2: Installing the Camera
1. With your RPi turned-off, install the Camara on its special port as shown below:
2. Turn on your Pi and go to Raspberry Pi Configuration Tool at main menu and verify if Camera Interface is enabled:
If you needed to Enabled it, press [OK] and reboot your Pi.
Make a simple test to verify if everything is OK:
raspistill -o /Desktop/image.png
You will realize that an image icon appears on your Rpi desktop. Click on it to open. If an image appears, your Pi is ready to stream video! If you want to know more about the camera, visit the link: Getting started with picamera.
Step 3: Instaling Flask
There are several ways to stream video. The best (and "lighther") way to do it that I found was with Flask, as developed by Miguel Grinberg. For a detailed explanation about how Flask does this, please see his great tutorial: flask-video-streaming-revisited.
On my tutorial: Python WebServer With Flask and Raspberry Pi, we learned in more details how Flask works and how to implement a web-server to capture data from sensors and show their status on a web page. Here, on the first part of this tutorial, we will do the same, only that the data to be sent to our front end, will be a video stream.
Creating a web-server environment:
The first thing to do is to install Flask on your Raspberry Pi. If you do not have it, go to the Terminal and enter:
sudo apt-get install python3-flask
The best when you start a new project is to create a folder where to have your files organized. For example:
from home, go to your working directory:
cd Documents
Create a new folder, for example:
mkdir camWebServer
The above command will create a folder named "camWebServer", where we will save our python scripts:
/home/pi/Documents/camWebServer
Now, on this folder, let's create 2 sub-folders: static for CSS and eventually JavaScript files and templates for HTML files. Go to your newer created folder:
cd camWebServer
And create the 2 new sub-folders:
mkdir static
and
mkdir templates
The final directory "tree", will look like:
├── Documents
       ├── camWebServer
               ├── templates
               └── static
OK! With our environment in place let's create our Python WebServer Application to stream video.
Step 4: Creating the Video Streaming Server
First, download Miguel Grinberg's picamera package: camera_pi.py and save it on created directory camWebServer. This is the heart of our project, Miguel did a fantastic job!
Now, using Flask, let's adapt the original Miguel's web Server application (app.py), creating a specific python script to render our video. We will call it appCam.py:
from flask import Flask, render_template, Response
# Raspberry Pi camera module (requires picamera package, developed by Miguel Grinberg)
from camera_pi import Camera
app = Flask(__name__)
@app.route('/')
def index():
    """Video streaming home page."""
    return render_template('index.html')
def gen(camera):
    """Video streaming generator function."""
    while True:
        frame = camera.get_frame()
        yield (b'--frame\r\n'
               b'Content-Type: image/jpeg\r\n\r\n' + frame + b'\r\n')
@app.route('/video_feed')
def video_feed():
    """Video streaming route. Put this in the src attribute of an img tag."""
    return Response(gen(Camera()),
                    mimetype='multipart/x-mixed-replace; boundary=frame')
if __name__ == '__main__':
    app.run(host='0.0.0.0', port =80, debug=True, threaded=True)
The above script streams your camera video on an index.html page as below:
<html>
  <head>
    <title>MJRoBot Lab Live Streaming</title>
    <link rel="stylesheet" href='../static/style.css'/>
  </head>
  <body>
    <h1>MJRoBot Lab Live Streaming</h1>
    <h3><img src="{{ url_for('video_feed') }}" width="90%"></h3>
    <hr>
    <p> @2018 Developed by MJRoBot.org</p>
  </body>
</html>
The most important line of index.html is:
<img src="{{ url_for('video_feed') }}" width="50%">
There is where the video will be "feed" to our web page.
You must also include the style.css file on the static directory to get the above result in terms of style.
All the files can be downloaded from my GitHub: camWebServer
Ony to be sure that everything is in the right location, let's check our environment after all updates:
├── Documents
       ├── camWebServer
               ├── camera_pi.py
               ├── appCam.py
               ├── templates
               |     ├── index.html
               └── static
                     ├── style.css
Now, run the python script on the Terminal:
<p>sudo python3 appCam.py</p>
Go to any browser in your network and enter with http://YOUR_RPI_IP (for example, in my case: 10.0.1.27)
NOTE: If you are not sure about your RPi Ip address, run on your terminal:
ifconfig
at wlan0: section you will find it.
The results:
That's it! From now it is only a matter to sophisticate a page, embedded your video on another page etc.
Step 5: Installing the Temperature & Humidity Sensor
Now it is time to see how to call a video scream form a web page. Let's create a page that uses real data like air temperature and relative humidity. For that, we will use the old and good DHT22. The ADAFRUIT site provides great information about those sensors. Bellow, some information retrieved from there:
Overview
The low-cost DHT temperature & humidity sensors are very basic and slow but are great for hobbyists who want to do some basic data logging. The DHT sensors are made of two parts, a capacitive humidity sensor, and a thermistor. There is also a very basic chip inside that does some analog to digital conversion and spits out a digital signal with the temperature and humidity. The digital signal is fairly easy to be read using any microcontroller.
DHT22 Main characteristics:
  • Low cost
  • 3 to 5V power and I/O
  • 2.5mA max current use during conversion (while requesting data)
  • Good for 0-100% humidity readings with 2-5% accuracy
  • Good for -40 to 125°C temperature readings ±0.5°C accuracy
  • No more than 0.5 Hz sampling rate (once every 2 seconds)
  • Body size 15.1mm x 25mm x 7.7mm
  • 4 pins with 0.1" spacing
Once usually you will use the sensor on distances less than 20m, a 4K7 ohm resistor should be connected between Data and VCC pins. The DHT22 output data pin will be connected to Raspberry GPIO 16. Check above electrical diagram connecting the sensor to RPi pins as below:
  1. Pin 1 - Vcc ==> 3.3V
  2. Pin 2 - Data ==> GPIO 16
  3. Pin 3 - Not Connect
  4. Pin 4 - Gnd ==> Gnd
Do not forget to Install the 4K7 ohm resistor between Vcc and Data pins
Once the sensor is connected, we must also install its library on our RPi.
Installing DHT Library:
On your Raspberry, starting on /home, go to /Documents
cd Documents
Create a directory to install the library and move to there:
mkdir DHT22_Sensor
cd DHT22_Sensor
On your browser, go to Adafruit GitHub:
https://github.com/adafruit/Adafruit_Python_DHT
Download the library by clicking the download zip link to the right and unzip the archive on your Raspberry Pi recently created folder. Then go to the directory of the library (subfolder that is automatically created when you unzipped the file), and execute the command:
sudo python3 setup.py install
Open a test program (DHT22_test.py) from my GITHUB
import Adafruit_DHT
DHT22Sensor = Adafruit_DHT.DHT22
DHTpin = 16
humidity, temperature = Adafruit_DHT.read_retry(DHT22Sensor, DHTpin)
if humidity is not None and temperature is not None:
    print('Temp={0:0.1f}*C  Humidity={1:0.1f}%'.format(temperature, humidity))
else:
    print('Failed to get reading. Try again!')
Execute the program with the command:
python3 DHT22_test.py
The below Terminal print screen shows the result.
Step 6: Creating a Web Server Application for Data and Video Display
Let's create another python WebServer using Flask, that will handle both, the data captured by sensors and a video stream.
Once our code is becoming more complex, I suggest Geany as the IDE to be used, once you can work simultaneously with different types of files (.py, .html and .css)
The code below is the python script to be used on our web-server:
# Raspberry Pi camera module (requires picamera package)
import Adafruit_DHT
import time
# get data from DHT sensor
def getDHTdata():
	DHTpin = 16
	hum, temp = Adafruit_DHT.read_retry(DHT22Sensor, DHTpin)
	if hum is not None and temp is not None:
		hum = round(hum)
		temp = round(temp, 1)
	return temp, hum
@app.route("/")
def index():
	timeNow = time.asctime( time.localtime(time.time()) )
	temp, hum = getDHTdata()
	templateData = {
      'time': timeNow,
      'temp': temp,
      'hum'	: hum
	return render_template('index.html', **templateData)
@app.route('/camera')
def cam():
	templateData = {
      'time': timeNow
	return render_template('camera.html', **templateData)
def gen(camera):
    while True:
def video_feed():
You can get the python script appCam2.py from my GitHub
What the above code does is:
  • Every time that someone "clicks"'on "/", that is the main page (index.html) of our webpage a GET request is generated;
  • With this request, the first thing done in the code is to read data from the sensor using the function getDHTdata().
  • Next, the actual time is retrieved from system
  • With the data on hand, our script returns to the webpage (index.html): time, temp and hum as a response to the previous request.
Also, a page "/camera" can be called when the user wants to see the video stream. In this case, the 3 routs as shown in the last step are called and the camera.html is rendered.
So, let's see the index.html, camera.html and style.css files that will be used to build our front-end:
index.html
<!doctype html>
<html>
<head>
    <title>MJRoBot Lab Sensor Data</title>
</head>
<body>
	<h1>MJRoBot Lab Sensor Data</h1>
	<h3> TEMPERATURE   ==>  {{ temp }} oC</h3>
	<h3> HUMIDITY (Rel.) ==>  {{ hum }} %</h3>
	<hr>
	<h3> Last Sensors Reading: {{ time }} ==> <a href="/"class="button">REFRESH</a></h3>
	<hr>
	<h3> MJRoBot Lab Live Streaming ==> <a href="/camera" class="button">LIVE</a></h3>
	<hr>
</body>
</html>
You can get the file index. html from my GitHub
camera.html
Basically, this page is the same that we created before, only that we are adding a button to return to the main page.
<html>
  <head>
    <style>
	body {
		text-align: center;
    </style>
  </head>
  <body>
    <h3><img src="{{ url_for('video_feed') }}" width="80%"></h3>
    <h3>{{ time }}</h3>
    <hr>
	<h3> Return to main page ==> <a href="/"class="button">RETURN</a></h3>
	<hr>
  </body>
</html>
You can get the file camera.html from my GitHub
style.css
body{
	background: blue;
	color: yellow;
	padding:1%
.button {
	font: bold 15px Arial;
	text-decoration: none;
	background-color: #EEEEEE;
	color: #333333;
	padding: 2px 6px 2px 6px;
	border-top: 1px solid #CCCCCC;
	border-right: 1px solid #333333;
	border-bottom: 1px solid #333333;
	border-left: 1px solid #CCCCCC;
You can get the file style.cs s from my GitHub
Creating the Web Server environment
The files must be placed in your directory like this:
├── camWebServer2
         ├── camera_pi.py
         └─── appCam2.py
                   ├── templates
                   │       ├── index.html
                   │       ├── camera.html
                   └── static
                           └──── style.css
sudo python3 appCam2.py
Step 7: Adding Video Stream on a Previous Project - OPTIONAL
Optionally, let's include the Video stream on the project developed on a previous tutorial
Let's use what we developed in my previous tutorial: FROM DATA TO GRAPH. A WEB JOURNEY WITH FLASK AND SQLITE.
As a remember, on that project we logged data (temperature and humidity) on a database, presenting the actual and historical data on a webpage:
We did this, using 2 python scripts, one to log data on a database (logDHT.py) and another to present data on a webPage via Flask WebServer (appDhtWebServer.py):
Creating the web-server environment:
Below I presented my directory view. Sensor_Database is under /Documents in my RPi:
├── Sensors_Database
       ├── sensorsData.db
       ├── logDHT.py
       └── dhtWebHistCam
               ├── appDhtWebHistCam.py
               ├── camera_pi.py
               └─── appCam2.py
                       ├── templates
                       │       ├── index.html
                       │       ├── camera.html
                       └── static
                               ├── justgage.js
		               ├── raphael-2.1.4.min.js
                               └──── style.css
The files can be found on my GitHub: dhtWebHistCam
Below the result:
Step 8: Conclusion
As always, I hope this project can help others find their way into the exciting world of electronics!
For details and final code, please visit my GitHub depository: Video-Streaming-with-Flask
For more projects, please visit my blog: MJRoBot.org
Saludos from the south of the world!
See you at my next instructable!
Thank you,
Marcelo
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    3 Comments
    Hi I was wondering if there is anyway for me to implement this onto my site I already have running on an apache2 server
    Nice work man.Have you tried digit recognisation over flask server using opencv.
    No, I am not. I did not work much with OpenCV yet, but it is in my plans! ;-)
