3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vietnamese Iced Coffee
Step 7Coffee Time!
Coffee Time!
When the dripping slows to a stop, peek inside to see the water level, if there is no water left, your coffee is almost ready! Remove the lid, and set it upside down on the table, then set the press pot on the lid so any drips will go into the upturned lid. Make sure you grab by those little black pieces on the sides of the pot, as the main pot will be very hot!
Now is the time to mix the milk and the coffee, for best dissolving. I have made the mistake of adding ice before mixing the two; the cold coffee isn't able to properly dissolve the thick syrup, and you end up with uneven coffee.
Once the two are properly blended, give it a taste. If you want, you can add more condensed milk at this point if isn't sweet and creamy enough. It should taste like really good melted coffee ice cream. Think Haagen Daaz stuff. If it were cold outside, you might like to drink it warm like this. But since it is summer now, I like to ice it.
I usually just throw a few ice cubes in the glass and call it good, but if you are doing it with style, you'll pre-chill another glass of the same type, fill it with crushed ice, and pour the coffee over the crushed ice. This dilutes the coffee less, because the ice doesn't need to cool both coffee AND the glass, but only the coffee. Less melting = less dilution. But I don't have many glasses, so I just add the ice to the brewing glass, and it works nicely.
Now just sit back, and enjoy! It took some time, but really wasn't much harder than drip coffee, and you will enjoy it much more. Plus, no yucky paper filters to deal with.
6 comments
Jan 17, 2009. 5:12 AMHelloid says:
I have a can of Dumonde that my wife bought in NO and didn't like. This sounds like the perfect use for it. I love thai iced tea, so this should be even better.
Feb 19, 2009. 12:50 PMsaintneko says:
Thai iced coffee & tea taste like water next to this brew. Though I prefer more grounds and vegan creamer, a must if you're lactose intolerant because condensed milk is like Drano if you're not. There is less sugar in the vegan creamer, a nice half-teaspoon of brown sugar or buckwheat blossom honey will do you. You can make two ounces of coffee SO black with the Du Monde that it takes 6 ounces of creamer to make it dark brown and it's STILL got the awesome better overtones to complement the sweet sugars and sourness of the acidity.
Mar 23, 2009. 9:25 PMbluemouse says:
Just a quick note - honey isn't vegan
Apr 13, 2009. 7:55 AMSooz says:
The author recommends the vegan creamer in this case if you're lactose intolerant, not if you're vegan. For vegans who prefer a sweeter brew, instead of the honey, one could use stevia leaves.
Apr 13, 2009. 1:08 PMsaintneko says:
Sugar is vegan. .
Jul 29, 2011. 4:08 PMfoxli says:
Fun fact: most mainstream refined sugar is processed with bone ash. So, not vegan unless it says so. :-)
Apr 13, 2009. 4:12 PMSooz says:
Bluemouse was telling you honey is not vegan. I was offering a substitute for honey.
Feb 22, 2009. 7:12 PMgadgetgod says:
I first tried 'Cafe Sua Da' in Vietnam a few years ago. When I came back to the US I tried to make it myself, but every time I do, the hot water flows through too fast or a get way too much sediment. Does it just take trial and error to get it just right, or should I try to get a new pot? Thanks
Apr 13, 2009. 7:50 AMSooz says:
There are a couple reasons for sediment. The most easily fixed is the "grind" of your coffee. Cafe Du Monde and several other canned coffee grinds are more coarsely ground and don't create as much sediment. I accidentally used an espresso grind once, talk about sediment (more like sludge). If you buy your coffee freshly ground, be certain you specifiy "coarse grind."
Also, make sure the press is screwed down snugly, because that makes less room for the water to swirl the grounds around. Less movement under the press = less sediment.
For the water going through too quickly, one thing I do is screw down the press, pour enough water in the pot to cover the bottom of the press, and then using the blade of a butter knife, screw the press down more. Screwing the press down again AFTER I add a little water gives me a slower flow and less sediment.
If none of these things help, your pot may have holes on the bottom that are too big, or your press screw isn't threading correctly with the post. Buy another pot. :-)
Hope this helps!
Sep 29, 2008. 7:00 PMMark Rehorst says:
Yeah baby! I LOOOOOVE Vietnamese iced coffee, and you have the method DOWN! There's no better way to cool off on a steamy, hot day in the jungle then to down a couple iced coffees and vibrate your way to coolness. I've been drinking this stuff for years and years and it hasn't affected my personality at all, so don't worry. Three thumbs up!
Feb 19, 2009. 11:48 AMWhoTookMudshark says:
Hahahahaha. The fact that that comment is voiced by "Tyler Durden" makes it even more hilarious than it already was. Don't worry! :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:phidauex
