3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Viewing Myself in 3rd Person
Step 5Constructing the Camera Mount
The camera mount system is made of 1/2" PVC. A frame is constructed and attached to a vest. If you don't have a vest, no worries. I just had one around. You can easily strap the frame to your chest with some straps. This may actually be better as it will hold the frame more closely to your back, whereas the vest had some play.
Extending from the frame is a T junction with the boom. The boom need more support so initially we added some string, and then some wire, but finally we decided we needed some more rigid support and added more PVC pipe.
Only the T-junction at the base of the boom was glued in. All the rest of the pieces are hand tightened.
It is important that the whole frame is rigid and well attached to your body. As we will see later, the motion of the camera relative to your body can make or break the experience.
The camera itself was attached by screwing the mount that the camera came in into a PVC cap. This work very well and it allowed us to adjust the camera angle which was very important.
Later we used some digital cameras to record the action at a higher res. Because the cap was just fit on, with no gluing, we were able to switch it out for a cap with a 1/4-20" bolt which screws into the standard camera mount. We cut a slot into the cap so that the camera viewing angle was adjustable. With the boom fixed it is important to be change the camera angle so that you can see yourself. Also, with different people wearing the suit, we needed to sometimes change that angle based on their height and preference.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:BigRedRocket
