(Video can be seen here: http://www.youtube.com/watch?v=2FvWtEdY4sE)
Frustrated by my obvious failure to reproduce a very very simple experiment I kept fiddling with the position of the magnet and the angle of the laser until I managed to get the laser to bounce off the mirror almost exactly at the center point of where the magnetic effect on the water was. Here is the result. Actually, there were two results. Not to far away ( the images were projected on my garage ceiling ) there was a different pattern. Image #2 below.
I can't say that I know what these images represent, but I imagine them being 2D representations of the underlying magnets effects on water. I'd be grateful if anyone could provide a more scientific explanation.
Anyways, here's what I used and how to reproduce the effects.
( Apologies for the blurry images, I couldn't with the tripod... again. )
Remove these ads by
Signing UpStep 1Equipment and materials
1 laser
Any old laser will do red, green, blue, anything within your visual spectrum is just great. The only thing I'd suggest you avoid is using a strong laser. If you're into laser you'll know the ones I mean: the dvd burner, blue-ray, I can cut through duct tape ones. Since you'll be bouncing laser beams off all over the place, I'd urge you to not exceed 50mW and at the very least use some sunglasses for basic protection.
Here's the one I'm currently using: http://www.dealextreme.com/details.dx/sku.10096
1 mirror
Size doesn't matter, it's how you use it. :) No wait! Erase that! Get something small enough to handle with ease.
1 small puck-shaped neodymium magnet
The one I used came with the Arduino sensor pack 900.
1 small metallic strip
or anything that you can use to move the magnet without moving the mirror.
some water
Distilled preferred, but not required.
something to elevate the mirror only slightly above the height of the magnet
[optional] a squid type third hand
It's a priceless tool and if you hadn't built one for your workshop I encourage you try. The most excellent instructable on how to do this is here: http://www.instructables.com/id/Third-Hand-A-multi-use-helping-hand-for-electro/
And I know why ;) Here comes your scientific explanation:
The pattern you see is a result of interference - basically, even though light is made of particles, it can act like a wave... and just like ocean waves, when they overlap, the crests and troughs add together.
In this case, the initial laser light is "coherent" - meaning all the photons are moving in a wave motion in lockstep throughout the beam. When the light breaks the surface of the water, a portion of the beam is reflected up and a portion refracted down - based on the angle between the laser and the water. The more perpendicular the laser beam is to the water, the more of it penetrates down. This also happens to affect the refraction angle.
The magnet produces a slight dimple in the surface of the water through diamagnetism, it acts like a very slight lens. The reflected waves are bent by this dimple in one direction (similar to a hyperbolic mirror) and the refracted waves in the opposite direction (hyperbolic lens)
The beam in the water then reflects off the mirror, passes through the air-water interface again (where, once again, it may be subject to both reflection and refraction), then finally bouncing up somewhere to meet the first beam.
The phase of the light at each point throughout the spot determines whether you see a light or dark patch there. Each area passes through slightly different paths in both the first beam and the second beam - if the first arrives as a crest and the second as a crest, you get a bright area. If one is a crest and the other a trough, you get a dark spot as the energies cancle out. If both are troughs, you get a bright spot. This is because light energy doesn't have a charge - there's no concept in the natural world of a negative amount of light.
