Retro Apple Disk Drive as HDD Enclosure
 by johnmueller
Contest WinnerFeatured
Fun update: this instructable was featured on lifehacker.com here.
The Inspiration:
I had this old Apple 800K External drive (Model No. M0131, P/N 825-1174-A) laying around and it dawned on me that it was about the same size as my Lacie External USB 2.0 HDD (Model 301103U) so I thought I'd try combining the two.  It would be fun for this diskette drive to have a useful reason for sitting on my desk instead of in a box or the trash.  You can read about the original details of this drive on Wikipedia here (under the section title "Macintosh 800K External Drive") if you're interested.
Tools Used:
-Phillips screw driver
-Dremel Tool (drill bits, router bit, cutting wheel)
-exacto knife
-butter knife
-hot glue gun
-tape (about any kind)
-wire cutters
For more how-to's visit my blog: John Fixes Stuff
Step 1: Disassemble the Apple 800K Disk Drive
First we'll get a good look at what is on the inside of this old drive and the space we have inside to put something different inside.  Go to the next step to begin the tear-down.
amandaghassaei says: Sep 18, 2012. 1:32 PM
looks great! love the extra touch with the led and floppy sticking out
johnmueller (author) in reply to amandaghassaeiSep 19, 2012. 9:12 AM
Thanks! Unfortunately I didn't have any retro floppy disks laying around so I had to use a double sided double density disk. It would have been best to put some old "classic" disk in there like After Dark where you could see the label but then again you would hate to saw one of those in half :)
johnmueller (author) says: Dec 4, 2012. 1:34 PM
It's a 1.5 TB. I'd guess they make that external drive in a bunch of different sizes with the same case.
'earl says: Dec 4, 2012. 12:41 PM
Is that a 500 GB seagate external I see in the bottom right? I believe so. I have the same external xD
Sweet ible.
poofrabbit says: Nov 27, 2012. 8:41 PM
Hey congratulations on being a finalist in the hack it contest! Good luck to you!
lhwong says: Sep 27, 2012. 7:47 PM
Great idea for a project!
Just a note: I've had a lot of experience cutting odd shapes out of computer equipment cases, and what I've done is very similar to your method, except I cut my holes smaller than I need, and then finish them off with small hand files. It you use hand files to file the plastic back after your initial cut, you can get some really nice, clean, finished edges because you go much slower and can examine your work after each set of strokes with the file. It takes a bit longer, but the results are awesome.
Anyway, just a thought for you future projects.
johnmueller (author) in reply to lhwongSep 30, 2012. 2:58 PM
That is a good idea. I once had a round file for sharpening chainsaw blades but have somehow lost track of it--that would have worked good for this project. The dremel isn't exactly a precision cutting tool and the holes in the back didn't turn out professionally, that's for sure. Lucky they are on the back and no one really sees them. Thanks for the idea.
adoroshenko says: Sep 28, 2012. 5:17 PM
Wow! That's an awesome project! I'm announcing it on my site - http://en.modmag.net/news/converting-an-old-floppy-drive-into-a-retro-external-hdd
thegrendel says: Sep 27, 2012. 3:06 PM
Don't throw away the guts of the floppy drive.
It has some reusable parts, including a nice
stepper motor, which you can use for another
project, i.e., another Instructable.
myamiphil says: Sep 27, 2012. 12:00 PM
Hmm.. I got an old Zip Drive.... maybe that'll fit a laptop drive drive
Max Headroom says: Sep 27, 2012. 10:08 AM
Nice-but does not beat the LaCie design...
therufs says: Sep 27, 2012. 8:51 AM
http://www.kareprints.com/ for icon inspiration? :)
blanchae says: Sep 27, 2012. 7:11 AM
Now to do that with a 5 1/4" floppy or 8" floppy drive.
nanosec12 says: Sep 20, 2012. 3:25 AM
Be careful not to leave that thing laying around, it looks 'original' enough that someone might consider it to be old useless junk, and toss it out...
Great Work
johnmueller (author) in reply to nanosec12Sep 21, 2012. 9:01 AM
Luckily it's plugged into the power strip and my USB hub!
dubstepmaker says: Sep 18, 2012. 2:17 PM
awesome man! super cool :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
