Introduction: Vintage Camera Nightlight
vintage camera nightlights! who wouldn't want one?
i've made a few different ones and posted some pictures on my flickr http://www.flickr.com/photos/jayfish/sets/72157627988114745/ .
some folks have been asking for a how-to so here's a rundown of how i make my nightlights. this is my first instructable so i'm sure i'll forget steps or something. i can also take more photos if anything is confusing.
i really enjoy making these so let me know what you think!
jayfish
also, if you'd rather just buy one from me, i have a few for sale here:
http://www.etsy.com/shop/jayfish
i've entered this instructable in the make it glow challenge! vote for me! and thanks for looking... :)
jayfish
Step 1: Parts
parts required:
vintage plastic camera
nightlight
candelabra base socket
misc parts that i had on hand:
heavy black cardstock (i cut up the dark slide from my polaroid instant film)
odd screws (3 to replace some drilled out rivets, one to screw the base to the nightlight.)
tools i use:
screwdrivers
wire cutter
needlenose pliers
wire stripper
small saw
dremel with cut-off wheel
soldering iron
hot glue gun
glue/epoxy made for plastic use
cordless drill w/various bits
xacto
matte or satin clear coat
black spray paint for use with plastic
a word about camera selection:
not all cameras will work for this instructable. when it's finished, the camera will be hanging from the receptacle so the lighter weight the camera, the better. also i'm keeping in mind how much of the camera will be sticking out from the wall as well as ease of disassembly/reassembly, room for the lamp socket, etc.
also, i really really like cameras so i'm not destroying any cameras that are in great/pristine condition nor any cameras that are rare (to me at least. if i can't find more than 2 for sale, i don't modify them until i do).
nightlight
tools i use:
screwdrivers
wire cutter
needlenose pliers
wire stripper
small saw
soldering iron
hot glue gun
xacto
Step 2: Camera Disassembly
the disassembly section.
the nice thing about older cameras is that most of them are pretty easy to take apart without destroying the camera in the process. when taking apart your camera, save all the parts & screws & pieces until you're done. you never know if you might need something to get it back together.
taking the kodak brownie starflash apart:
unlock and slide out the bottom/film transport section. (did you find film? wind it up and mail it to me!)
remove the two visible screws that keep the top and bottom sections together.
unscrew the back of the flash housing (remove & recycle any batteries found in there!).
to separate the two halves of the bottom section:
if your camera still has the neckstrap attached or if the neckstrap buckles are still in place, you'll need to pry them open. i use two pairs of needlenose pliers, each one grabbing one side of the buckle then gently open the buckle enough to remove it.
after that, i use a small flat head screwdriver to gently bend the top of the aluminum clips so they clear the plastic neckstrap attchment points then the aluminum pieces slide down. you should now have two separate halves.
breaking things down further...
the bottom/film transport section:
remove the two screws from the bottom and separate the two pieces. i use wire snips to
pry the chrome metal part off the base. at this point i also slide out the small rectangluar(ish) metal part, remove the metal locking pin thingy and then snip off the somewhat circular shaped plastic bit. i use this to cover the hole left by not having the locking pin in place.
the flash section:
unscrew the flash ejector (save all the parts)
drill out the three visible rivets to separate the needed pieces.
you can discard the rivets or try and save them to glue back in later but i just replace them with screws.
the front/shutter section:
use wire snips to slide off the two brass strips. they're just friction held in place.
drill out the two rivets that are visible when looking at the inside and remove the metal plate. this will allow access to the shutter mechanism. then i flip the section back over and drill out the lower 3 rivets. this should release the shutter, the aperature, and other misc pieces of metal. i don't drill out the rivet that attaches to the shutter lever. i think keeping it movable is a nice touch.
i then use a dremel with the cut-off wheel to remove some of the extra metal on the shutter lever, this makes it lighter and makes things easier as we go along.
the flash section:
Step 3: Removing Plastic
i've got one word for you; plastic.
let's remove some to save weight and some to allow access for the nightlight.
on the front section, i draw a line showing what i want to remove while still maintaining structure and connection points.
i also will remove some of the top part of this to allow wire access.
on the rear section, i use the nightlight as a template, marking where i want it to be located. i remove this as well as some of the top part to allow wire access. when cutting the slot for the nightlight, i will cut it just shy of the line then use a file or sandpaper to fine tune it so i don't have gaping holes around the plug. this is also a great time to add something to cover the film counter window. i use a piece of film backing paper but you can use whatever you like to make it personal. perhaps a little picture of you or your sweetie pie?
on the base, i cut away anything that's going to be in the way of the nightlight. on mine, it's going to sit flush so i make sure it's flat.
Step 4: Modifying the Nightlight
on to the nightlight!
the one i bought has a nice electric eye so it will turn on/off at dusk/dawn and also has a screw attaching the two halves of the housing. i think this is the most important part because if i have to break the nightlight to get it open, it's going to be a pain to get it back together.
dis-assembly is simple enough. slide off the plastic lens, remove the bulb, pop off the circular bit, remove the screw, then pry the two halves apart. you can then slide out the prongs/electric bits.
i discard the lens and snip off the plastic cast socket as i have no use for it.
the next step is to desolder the electric eye and the bulb contact.
i then solder a longer lead/wire onto the electric eye and another one to one of the prongs. i then solder these back onto the board.
test your handiwork by screwing the open wire to one of your sockets.
Step 5: Modifying & Attaching the Lamp Socket
taking apart the light socket.
remove the cardboard tube
drill out the rivet that's attached to the screw-in metal bit.
remove the screws.
i then pry up the clips on the brass side to allow the socket to come out.
then use the dremel to take off the metal attachment points on the socket.
next, i spray a couple coats of matte varnish on the front of the aluminum flash housing (not the socket) this should insulate any wandering fingers from shock when we're all assembled.
i then trim some of the aluminum flash housing (from the flash assembly in step 2).
we need to widen the opening to allow the socket to fit. i do it slowly so i don't stress/break the metal & also so i don't end up making it too big.
once you've got it to fit, you'll need to join the two pieces. i use a flat head screwdriver the bend the aluminum housing around the socket then i use an awl to poke a few holes through both pieces. this should keep them together but i'll also add some glue later.
next step is to cut off a bit (how much depends on how far the socket sicks out of the aluminum housing.) of the plastic socket housing. i use the dremel but you can also use a small saw. then i glue it in place.
the last step is to reassemble all of the flash section. you can try to glue the drilled out rivets here or find suitable replacement screws.
remove the screws.
Step 6: Assembling the Nightlight in the Camera
starting to put it all together.
i make a small surround for the electric eye by cutting out a small piece of heavy cardstock and tracing the shape of the eye on it. then i use an xacto to cut the hole. it should be snug enough that you won't get any glue seepage.
i don't have it pictured but you should assemble the nightlight housing now. if you removed the lens on front of the nightlight, you can thread the electric eye through the hole.
next, i put the eye where i want it to be located and glue it place. when the glue has dried, turn over the front panel and glue on the shutter button.
solder the open leads to the socket on the flash assembly.
test your light once more before you start sealing everything up.
Step 7: Final Assembly
home stretch.
i add a piece of electrical tape to the flash ejector so i don't run the risk of shorting out the socket. then i screw the flash ejector back in place.
next, i glue & screw the back of the flash section onto the front.
then we'll make sure all our wiring is going the right way and glue the two halves of the bottom section together. slide the aluminum clips back on and bend the tops back over the neckstrap lugs.
attach the top and bottom together with the two screws inside.
lastly, we'll be screwing the nightlight to the base so start by making hole in the base for the screw. dry fit/hold everything together and decide how far you want to the plug to come out. use a pencil or awl the mark where to drill the corresponding hole in the nightlight.
add some glue to the base and clamp everything together. screw the bottom to the nightlight and you're done!
okay, what did i forget?
