Step 3Removing plastic
let's remove some to save weight and some to allow access for the nightlight.
on the front section, i draw a line showing what i want to remove while still maintaining structure and connection points.
i also will remove some of the top part of this to allow wire access.
on the rear section, i use the nightlight as a template, marking where i want it to be located. i remove this as well as some of the top part to allow wire access. when cutting the slot for the nightlight, i will cut it just shy of the line then use a file or sandpaper to fine tune it so i don't have gaping holes around the plug. this is also a great time to add something to cover the film counter window. i use a piece of film backing paper but you can use whatever you like to make it personal. perhaps a little picture of you or your sweetie pie?
on the base, i cut away anything that's going to be in the way of the nightlight. on mine, it's going to sit flush so i make sure it's flat.
Add Comment
