Introduction: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
My daughter came back from college for the summer and wanted an upholstered arm chair for her bedroom. Since, as I mentioned, I have a kid in college, buying a new arm chair wasn't in the budget. Nor was I crazy about buying used fabric covered furniture because of bedbugs, smoke, pet odors, etc. So I looked around the house to see what I could come up with.
Step 1: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
I had this old chair that my dad had purchased at a thrift store back in the 60's. My daughter and I made a trip to the fabric store and purchased some foam and material. I used upholstery tacks, a staple gun, quilt batting, cardboard, scissors, and a hammer.
Step 2: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
It had some structural problems. So the first step is adding several screws to make sure everything holds together. I am going to be flipping this chair around a lot.
Step 3: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Next step is making a pattern of the seat shape. I had an old piece of pink material that I laid across the seat and traced the outline on.
Step 4: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
It doesn't have to be perfect. I just need a rough guide for cutting the foam.
Step 5: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Then I put the pattern on a piece of foam that I purchased from my local Hancock Fabrics store. It is made from soy and supposed to be green (ecologically friendly.) It was also on sale. (my major motivation) The foam is 2 inches thick, so I plowed through it with scissors. An electric knife would work much better. If the foam was thicker or I was doing more than one of these, I might have tried to find one.
Step 6: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
The foam was green. I mean really, physically green. So I decided to put a layer of muslin on first, so the green wouldn't show throw my print fabric. Plus, I figured it would make the upholstry stronger to have 2 layers. Next, I draped the muslin over the foam and cut out a rough seat shape with plenty of overhang. Later, it occured to me I could have used my pattern I just made and added all around. Ah, hindsight.
Step 7: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Then I pulled the fabric down around the seat and stapled it in place. Where it met the legs and arm supports, I cut a small slit in the fabric. Small. It is much easier to cut more than to fix a slit that is too big.
Step 8: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
The stapled muslin right side up.
Step 9: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
I put the second piece of foam on the chair and just traced around it. Then I cut it out. See the extra on the top? I am going to be using that shortly.
Step 10: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Foam back in place. I draped it with muslin and stapled again.
Step 11: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Using the piece of foam left over at the top of the back piece, I cut out two arm pieces.
Step 12: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Drape and staple again.
Step 13: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
The back looks pretty bad at this point. So I cut a piece of cardboard to fit over the back.
Step 14: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Then I cut a piece of quilt batting, a piece of muslin, and a piece of the final fabric. Love this print. Love the fact that it was half price on the clearance table.
Step 15: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
I sewed the three layers of fabric around the cardboard. This long thread tangles easily.
Step 16: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Finished back.
Step 17: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
It's time for more draping and stapling, this time with the print fabric.
Step 18: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Almost there.
Step 19: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Now I turned the chair over and used upholstry tacks to fasten the cardboard cover down. I always buy twice as many tacks (.97 at Walmart) as I think I need, because I invariably hit about every third one wrong. Then it bends over instead of going into the chair back. This 50+ year old oak was especially hard, so I ruined a lot of tacks.
Step 20: Vintage Chair to Vintage Flair (Upholstering a Wooden Chair)
Finally, I covered the bottom with a piece of cardboard. I could have covered it with fabric, too, but I was tired at this point. Nobody will be looking under the chair, anyway.
Step 21:
The finished chair. If I was doing this for chair that would get more use, I would have used upholstery material. Since this one is mostly decorative, the apparel fabric will work.
Fix It Contest
Vintage Contest
