Vintage Tricycle Resurrection with Modern Technology
 by vanweb
Contest WinnerFeatured
Step 6: Vinyl-cut Fender Graphics...
As I stripped away the paint I uncovered the original fender graphics which were in remarkably good shape. They were a cool retro arrow design that I really liked. I knew that I had to replicate them on the restored trike. I imported the hi-res photo of the fender graphics into CorelPaint and cleaned them up as best I could. Reduced colours, erased defects, converted to Black & White etc. This image was then imported into CorelDraw to make a vector. I hand traced the image using the line tool then deleted the original image to be left with only a vector drawing. I then cleaned up the vector to make the curves smooth and the corners sharp. Using guidelines I adjusted for the curve on the original fender photo and resized the image to match the fender. I flipped the image for the reverse side of the fender (and doubled it in case I screwed up the installation), finally I exported the vector to an Adobe Illustrator file suitable for my local sign guy.
I dropped off the file on a usb key at noon and chose a light tan vinyl that perfectly matched the paint color on the rest of the bike. 3 hours & $15 later I had the cut graphic in my hand! Application was easy just peel and stick, it went on perfect and looked amazing! Without a computer and a digital cutter this would have to have been manually cut or even worse manually painted. I cannot see any way that it would have turned out as perfect as it did without today's technology for an amateur restorer like myself.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
