3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vintage Tube Radio & MP3 Upgrade
This i'ble will take you though the restoration of a vintage tube radio to near-original condition and in the process, upgrade it to play to MP3s with a low cost, easy to build AM transmitter.
This project does not rely on making permanent changes or modifications beyond cosmetic repair and is a great way to introduce novice electrical, radio, or woodworking enthusiasts to what was once the entertainment equivalent of a 60-inch LCD TV.
The model used in this rebuild is a 1936/1937 Emerson AL130 purchased on eBay for less than $60 with restoration/upgrade components rounding out to around $150 (includes Priority shipping).
From Radiomuseum.org
Manufacturer/Brand:
Emerson Radio & Phonograph Corp., New York, NY
Model: AL130
Country: United States of America (USA)
Year: 1937
Type:
Radio / Tuner
Valves / Tubes: 5 total (6A7, 6D6, 6Q7, 25L6, 25Z5) + Balast
Audio: Principle Super-Heterodyne (Super in general); IF-Freq 456 kHz; 2 AF stage(s)
Band: Tuned circuits 6 AM circuit(s), Wave bands Broadcast (MW), Police, sometimes also early TV (75-200m).
Power type and voltage: AC/DC-set / 105-125 Volt
Speaker: Loudspeaker Electro Magnetic Dynamic LS (moving-coil with field excitation coil) / Ø 5.5 inch = 14 cm
Material: Wood case (Ingraham Cabinet, Bristol, CT)
Shape: Tablemodel, Mantel/Midget/Compact but not a Portable (See power data. Sometimes with handle but for mains only).
Notes: BC(540-1580kHz) and TROP(1580-4200kHz) bands. Uses 49 volt ballast tube.
Step 1Finding a Donor
Finding a Donor
The first step is to dig around the innerwebs and look at some of the styles manufactured during different periods, taking note of the frequencies they operate in. The most common bands are AM, FM, ShortWave, and Police. Actually playing The Police through your radio is optional, but highly recommended.
Once you get a general idea of what size/shape/era you like, research a few makes/models to determine the rarity of parts in the event your radio is missing components.
DO NOT PLUG IT IN YET! Doing so without giving it a look through for short circuits, bad wiring, or living things (not a joke) may be the last thing you do in this world or at the least, justify nasty looks and name-calling from your local firefighter.
In our example, the AL130 is quite common in that it only needs 5 tubes a balast, and a few capacitors. This is commonly known as an "All American 5" (AA5) design and makes parts easy to track down through various online suppliers.
The following links proved indispensable during the course of this project...
Information resources:
http://www.antiqueradios.com/forums/index.php
http://enginova.com/Antique_Radios.htm
http://www.antiqueradio.org/begin.htm
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=5584
http://www.nostalgiaair.org/
http://www.radioremembered.org/ballast.htm
Parts:
http://www.tubesandmore.com/
http://www.justradios.com/
http://www.oldradioparts.net/caps_mylar.html
http://www.vacuumtubes.net/index.html
11 comments
Dec 6, 2011. 12:58 PMRobert L says:
This may be slightly off topic but does anyone one know any substitute for the stuff covering the speaker.
Dec 7, 2011. 10:20 AMRobert L says:
That was extremely helpful. Thank you. I'm making my own radio/mp3 player like this but I want to make it from scratch. I'll put up a picture when I've finished.
Aug 3, 2011. 12:38 AMmleeuw van weenen says:
i love this kind of instructable. And i seems to be well laid out. So thanks a lottttt.
Nov 15, 2010. 12:45 PMMerleCorey says:
I was thinking the AA5 had to include a 50C5 power tube...hmmmph really i dont remember.....yes it alway depends on who you ask and if tey feel comfortable, however.....remember a dummy will plug the plug in backwords, even a genius might not know the state of the romex inside the wall, thats why i warn.....build any tube stuff from scratch? this is a good step in that direction.
Nov 11, 2010. 9:35 PMMerleCorey says:
isolation transformer ...this is danger city...if you were to plug this in as wired into a socket that was "accidentally" reverse wired, the chassis, and anything conductive that touches it would be hot....and your the ground. BUUUUTTTTT once you make it safe this probably sounds great! you know if you want that tube sound you can just use barbed wire instead of speaker wire....thats what the pros use.
Nov 6, 2010. 8:49 AMjkave says:
Nice instructable.
For safety sake, anyone considering repairing an old radio like this should also consider adding a polarized AC plug, safety capacitors and an isolation transformer.
Nov 5, 2010. 6:11 AMmattthegamer463 says:
I love it. 99% of these projects are Step 1: Gut this junk, and it makes me cry. Very nicely done sir.
Nov 5, 2010. 6:09 AMPeale says:
Nicely done, sir. I especially like that no permanent modifications were done.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:M3talhead
