Vintage Bookcase With Legs
3,154
97
5
Posted
Introduction: Vintage Bookcase With Legs
Book It! Contest
Runner Up in the
Book It! Contest
Because I did not take pictures of the above steps, I drew what I did.
I had a vertical bookcase, which was awkward to use. So I decided to change it.
Step 1:
I disarmed the entire cabinet (which had made myself) and cut the shelves.
After i hid the screwheads, with the appropiate paste, y painted two coats of white, and two coats of turquoise paint.
Step 2: Refurbishing Legs!
This is the part that makes me feel more proud.
These legs belong to a desk that my aunt was going to bounce. I asked her to give me the legs for my next instructable It was her first desk
So, i sanded and add water to see how there going to be.
And also remove the extra parts.
Step 3: In My House
Then i took the sanded legs to my house, where i cut them in a 90 degrees angle. And cut it a little, because there where too long.
I gave three layers of lacquer
Step 4: Make a Template for the Dowels
I started making a square on a piece of cardboard, trace the legs, marked an X and did other marks where the dowels will be.
I use the template for the legs and the case.
Then drill the whole marks. (4 in each leg, and 4 in every corner of the base)
Step 5: Glue the Dowels
Put pva glue in the dowels, and the base of the case.
For the safety of my floor, i inserted some nails with plastic head, that i had for another proyect. Drill a smaller hole in the center of each leg.
I do not even remember where I found the plasticheaded nails
Step 6: And Thats All!
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
5 Comments
So shiny! Did you lacquer the turquoise paint as well?
Beautiful!!
It definitely lacks rigidity. You'll need to add a rib underneath the case and at least one diagonal brace.
yes I had thought, but will opt to locate books on the sides. And at the center, only ornaments, like my paper mache figurines or one of my illustrations framed.
Thanks for your comment
This is a really beautiful project. You should definitely enter it in the furniture hacks contest. Thanks for sharing
i tried, i do check con the square, maybe i didn't get in. Thanks forma tour comment! :)
