A record bowl is a classic project where you can reuse an outdated item: a vinyl record. With CDs even on their way out it's safe to say that many records can be safely molded into something new without the world losing any of its music.
In this Instructable, I will be showing off two versions of this bowl. The classic style and a newer one.
Step 1: The classic record bowl
Reshaping the vinyl requires getting the record a little hot. Not too hot, though.
The easiest way of doing this is to set your over for 220F/100C and tossing the record in there for a few minutes. When it's completely warmed up it will have the texture and floppiness of a fruit roll-up. You can now shape it any way you want.
Other methods include dipping the record in boiling water or heating it up with a heat gun.
Step 2: Shaping the bowl
To shape the bowl you can do a few different things. You can:
- drape the record on top of a bowl. Once the record cools it will have a similar interior shape as to the bowl.
- drop the record into a bowl. The outside of the record bowl will then have the same shape as the bowl.
- drape the record on top of a cylinder such as a can of soup.
Once the record cools, it will harden into place and stay that way. If you're not happy with it, just toss it back in the oven for a bit and start over.
Step 3: Record bowl with cuts
This variation starts with some cuts in the record to help guide the shape. The cuts here were made with a rotary tool like a Dremel.
The cuts here are lines that begin at one circle and end at another. Each cut ends 30 degrees off from where it began. So if one cut were to begin at 12 o'clock on the inner circle, it ends at 1 o'clock on the outer circle.
Step 4: Heat and Shape
Set the oven to 200 degrees and drop the cut up record in for a few minutes. If you set it up on a beer can (photo from lamp shade instructable) you can see the vinyl begin to sag when it gets warm enough.
Working with the vinyl is a funny thing. When it gets hot the vinyl is floppy and feels almost like fruit leather. After a few seconds you can shape the vinyl and it will begin to hold its shape. At this point, start working the material as fast as you can. Even with just 12 bends to make on the record I didn't have enough time to get everything right.
The good news is that you can hit the reset button by putting the record back in the oven. If you want to completely start over, heat it until it gets back to the floppy stage.
To just finesse a couple parts of the piece you will have to be much more attentive. Turn the light on in the oven if you can and watch carefully. Once the record starts to sag just slightly, open it up and take it out. This should give you enough time to fix a couple of bends. Repeat as necessary.
If you have a heat gun you can heat up a localized area to make specific fixes.
Step 5: Fill with Fruit
If you're going to put some food in the bowl you should wash it with some warm soapy water first.
Enjoy!
1-40 of 80Next »
tbgtbb says: Mar 12, 2013. 2:00 PM
It is utterly appalling that people are doing this to these pieces of history. It's like taking old books and making them in into toilet paper. You all should be ashamed.
cdcrock says: Dec 3, 2012. 3:41 AM
I really like this I have so many out dated records and know clue what to so with them, now I do. Tks
rrkrose says: Nov 4, 2012. 11:35 AM
I really want to try making but our oven isn't working so I was wondering if I could make this a heat gun. Thanks.
Scotttland says: Nov 23, 2012. 2:13 PM
the price of living in a trailer
fungus amungus (author) says: Nov 5, 2012. 10:20 AM
Yes you can. You need to be more careful about it to get it evenly heated and not overheat it, but definitely doable.
bobert610 says: Jun 18, 2012. 8:02 AM
anyone know if the vinyl can be handled with bare skin after the heating process? or is it too hot, because like some materials IE aluminum foil, it is safe.
Osquar says: Jun 8, 2012. 5:16 AM
Thanks for the inspiration :D
I made a few of these for a party I was hosting where the theme was "retro"! We used the big LPs as tip jars and the really small ones for nuts and chips (I made sure to wash them properly before and after usage of course by hand). Was too popular though so now I only have like two out of 15 left :/
fungus amungus (author) says: Jun 10, 2012. 8:30 PM
Nice! Never tried this on a single so glad to hear that worked. Would be even better with color vinyl.
WhyHello says: Dec 31, 2010. 1:46 PM
I'd feel so bad! but there is this guy always trying to sell his old records!
do u have any ideas what to make out of VHS movies?
OrlandoArtist says: Feb 29, 2012. 7:40 PM
I've been wondering that myself. VHS are cheaper than thrift store vinyl at some places. People have even given me box loads of them. What to do? I'm always up for making a chair with them like Legos. haha
farflungfloyd says: Dec 21, 2011. 3:14 AM
Can I coat the vinyl with some sort of protective layer? Like a varnish or something like that?
Goodhart says: Jan 7, 2012. 7:24 AM
AFTER being fired in the oven, I wouldn't see why not.....just test it first, if it is solvent based, to make sure it doesn't end up melting/dulling the surface of the vinyl.
emilicious9800 says: Aug 26, 2011. 1:40 PM
How do you hold it while its hot? is it too hot to touch once out of the oven?
fungus amungus (author) says: Aug 26, 2011. 4:44 PM
It's hot at first, but cools down pretty quickly. I would slide it out and hold it by dancing my fingers underneath it so I didn't touch it for long. After a few seconds it would cool enough to hold.
Then again, I have a higher tolerance for pain than most. YMMV
tinker234 says: Aug 2, 2011. 8:39 AM
hey could i add a plastic coting to make it food safe are these microwave safe thatnks tibnker 234
doomsdayltd says: Jul 26, 2011. 3:05 PM
great i knew i should of picked up some vinyls from the thrift store last time i was there, making nice things from crap that Barry Manillow made
JohnDeere312 says: Jul 12, 2011. 11:05 AM
Just finished mine! They turned out great! I got some records at the Salvation Army for 50 cents a piece, its like a 50cent bowl! They're awesome and perfect for jewelry bowls and snack bowls! Great instructable and project!
ArtsyFartsyGirl says: Jun 23, 2011. 10:38 PM
SACRILEGIOUS!!!!!!!!!!!!!!!!
ArtsyFartsyGirl says: Jun 23, 2011. 10:27 PM
SACRILEGIOUS!!!!! My old albums are almost my most valued possessions!!!!!!!! But I do like that Dali clock!
Twinmum says: Apr 3, 2011. 4:35 AM
This made me smile. When I was a kid, I learnt to do this at a holiday club I think. Back then, old 78's were still reasonably easy to get and they soften a lot easier. I think we just had to soak them in hot (boiling?) water.
Norma
spue says: Mar 20, 2011. 4:50 PM
Nobody has mentioned that "Vinyl" also known as Poly Vinyl Chloride releases carcinogenic gasses when heated. It is TOXIC stuff. I make these outdoors on my gas BBQ. NOT INDOORS!
excessive.insurgence says: Jun 16, 2010. 7:40 AM
is this dish washer safe? or does it need to be hand washed?
Harrison7042 says: Mar 6, 2011. 6:31 PM
I would suggest hand washing it with medium hot water and soap. As it might deform, causing you to have to redo it. I hope that helps.
surfreak says: Aug 19, 2010. 1:16 PM
I'd worry about the heat from the dishwasher melting it. Best to hand wash IMO. But hey, you can always "hit the reset button" by putting it back in the oven. So try it out and find out.
ThreeWestCreative says: Dec 7, 2010. 12:26 PM
I forgive you for your assault on the best sounding music medium on earth (as I put the needle on one of my 150 records). hahahahahaha HOWEVER, since I tend to buy records from thrift stores with the occasional crap record misplaced in the record jacket of something HOT, I would love to use those to make awesome bowls for my home. :) Thanks!!!
shewasjustso says: Aug 18, 2010. 2:23 AM
A perfect use for my old Hall and Oates, and Huey Lewis and The News records. Thanks so much!!
studystudyforever says: Jun 14, 2010. 7:43 PM
That great, thanks
adsandy says: Dec 19, 2009. 11:24 AM
This is a great instructable- thanks!
cooldog04 says: Nov 28, 2009. 10:22 AM
By "a few minutes" they mean 5-10 :) just to clarify
fireman115 says: Oct 4, 2009. 2:29 PM
That"s the pic from the hanging record clock
a02138 says: Aug 12, 2009. 3:56 PM
sweet tutorial. thanks!
alessiof76 says: May 19, 2009. 1:12 PM
Great idea!
Please tell me that vinyl was ruined or I start crying!
I prefer analogic music..
I'll try whit CD bowl but i must find very little fruit for it !)
ReCreate says: Jun 4, 2009. 11:46 AM
cassette tape is about as analog as you can get now a days
alessiof76 says: Jun 4, 2009. 1:04 PM
I had a nice sound system I sold to get married and buy the house turntable, preamp and amplifier vacuum tubes (selfmade) horn loudspeaker selfmade (80Kg for each I won an award for these in 1998) but I think the turntable sounds better than CD unless you pay over 5000 euros I have hundreds of records but do not throw away no one maybe I am mad but is just my opinion
ReCreate says: Jun 4, 2009. 1:16 PM
records to me are: Over sized Contain Small Amounts of data, In this case, Music The music sounds bad it just sucks
alessiof76 says: Jun 4, 2009. 1:45 PM
If a player your turnabe costs less than $ 1200. I agree with you: is the better CDplayer. but if you want to listen to REAL music you need to spend a lot (or rather listen to live music) if you not distinguish the mp3 from the CD is better to close the speech
ReCreate says: Jun 4, 2009. 4:37 PM
Yeah, Even worse. They Produced low quality sound And they are complicated, Thus expensive for one that will sound better than average players
naruto the ninja13 says: Jun 3, 2009. 3:38 PM
are this things food safe? cause once im rich im opening up a 1960s stlye resturant and imagine eating spaghetti of a real record!
thepelton says: May 19, 2009. 10:47 AM
I recall making something like that about thirty five years ago. Made a great flowerpot, since you didn't need to add a hole in the center of the bottom for drainage.
bustedit says: May 19, 2009. 8:50 AM
cool. im going to try making a hat, by heating it up and letting it drape over my head as it cools. here's an idea - how about using a record to make a coaster? just use the label section, about the right size for a coaster, then laminate or seal the label so it is waterproof, or something. some labels look really cool.
1-40 of 80Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
