loading
The saddest thing about the advent of digital music might be the loss of album art. At 12" X 12", a vinyl album sleeve is the right size and proportion to be a work of art worthy of hanging in a gallery. I made these vinyl record frames to display my favorite cover art while keeping quick access through a slot in the top.
Step 1: Design
The frame needed to have a cavity with beveled corners at the top to allow the record to slide easily in and out, and needed trim for the front of the frame to keep it in place. I made the interior space 12 7/16" wide to give the sleeve some room to move easily in and out, and made the frame just barely cover the edges of the sleeve at 12 1/8" across in each dimension. It's important to obscure as little of the sleeve as possible because most album art goes all the way to the edges.
Although vinyl sleeves maintain a 12" X 12" perimeter within a few millimeters' tolerance, they vary widely in thickness. Because of this, I doubled the intermediate piece to make the gap bigger.
I left the front of the frame open so that you can just slide the record out by hand quickly to throw it on the turntable.
Step 2: Templates and Assembly
The templates are attached in this step for easy fabrication. I laser cut these pieces because it was the fastest way to do it, but this could easily be fabricated using the method I described in my Digital Fabrication by Hand instructable.
The PDF should be printed at 36" X 36" as shown in the layout, but you could also tile smaller pages for the same effect. That being said, this design is so simple that it might be easier to just go with the dimensions on the diagram in the previous step and just lay it out with a pencil and straight edge.
I cut out the trim pieces with mitered corners to save wood, but it might be easier to just cut everything out in whole pieces as shown in the templates since the separate pieces are tricky to line up perfectly.
The assembly process is super simple- just glue, brad nail, and clamp together until the glue dries. I recommend finishing the wood before assembly since it would be tricky and messy to get the finish into the record cavity.
I added some keyhole hangers to the back of the frame when I was done- this seemed like the most secure way to hang the frames on the wall. Using picture wire would be tricky since presumably I'll be taking these records out frequently to play them.
Step 3: Listen in Style
I'm really happy with the way these turned out. Records of varying thicknesses slide in and out easily, and it's nice to have a revolving gallery of album art in my living room.
<p>I Made it! It was a bit more work than I expected but I am very happy with the outcome. The plans were great! Thank-you to the original creator for posting the idea. I changed it up a little bit to fit my materials/tools I used a single square sheet of 1/4inch plywood and instead of making U's (to save on material) I made stripes and glued everything together with wood glue as you can see. plywood has the tendency to have tear out so I used a table saw for the strips and a circular saw to cut 45-degree angles on them to connect the strips. I also changed the front square frame and made it slightly larger (1 inch) for my preference. In total I think one frame cost me about 7$ to make.</p>
<p>Well done! These look way better than mine. Thanks for sharing!</p>
Fantastic idea! Great instructable. Thank you for this.
Fantastic Instructable, Jon~ It's so refreshing to find folks who still appreciate anything connected to vinyl LP's
<p>I love yur ideas:)</p>
<p>Great concept and many possible ways to refine the idea. BUT...as a museum consultant and professional framer I beg you: please, please be sure to seal any part of your frame that will come in contact with your album cover with some type of acid free tape. One of the comments about UV glass should be considered as well. Plain window glass provides about 1% UV protection. Acrylic provides a bit more but (can) introduce gases toxic to your album cover and/or vinyl disc. If you must display your album in direct light (sunshine or fluorescent) invest in UV protective glass such as Tru Vue(tm) available through most frame shops.</p>
<p>Straightforward and classy looking...I'm definitely adding this to my project list.</p>
<p>Thank you for this project. Very nice.</p>
<p>OMG!!! Autobahn! Where did you find it? And is it the german version or the english version? </p><p>Thank you for this project, it is very nice.</p>
<p>I got that one at Amoeba. It's the English version, but it's still awesome! http://www.amoeba.com</p>
<p>Thanks. I didn't know this website.</p>
While i love this idea i'm super poor at the moment from spending too much on vinyls (the irony). I'm going to try use my corrugated card roll and let you know how that pans out :)
<p>Sounds legit to me! I love corrugated cardboard as a building material.</p>
<p>JON-A-TRON, please find my website www.ecorglobal.com. I NEED to talk with you about what I am doing that is very similar to your frames. We are making something with our 100% chemical/VOC free material ECOR that you may be interested in. My email address is joestapley@ecorglobal.com Send me an email and I will call you if you are interested. </p>
<p>ECOR!!! You're not going to believe this, but I saw you guys at a green building expo in SF like 5 years ago. I've been thinking since then that I should reconnect and se what you're up to and what new products you might have. I was amazed at how lightweight / sturdy / flexible your samples were. I'll email you shortly.</p>
<p>How about some of the iron-on veneer to hide the ugly plywood edges?</p>
<p style="margin-left: 20px;">Call me a purist, but I like exposed plywood edges. I find iron-on veneer to be dishonest...</p>
<p>No, not really, as it is also made from wood, and also then plywood which you have already used. A purist would only use a solid wood:) OK, it is just a fine tuning of finishing work. For exhibits, no one likes the look of the more raw edges unless it is painted. Therefore the idea of the iron on edging, (which by the way usually has to be put on with contact cement anyway, or so I find) makes it less rough, and more finished in appearance, especially if you stain and finish the surface with a satin poly. Anyway, it is certainly a choice of taste, or in my case what is excepted as a finished product in the field. There are standards of presentation that must be looked at as well. Museum exhibits, science, Nature Centres etc, want a finished look to the work. Unless of course it is part of the 'theme' in presentation. Rarely do you have plywood edges exposed as it is not considered to then be a finished display presentation also due to the look of saw burned edges that is not uniform nor polished in appearance. You can also use the plastic edging to finish edges if you happen to use the surface material with the synthetic top finished products. Just a thought:) Anyhoo, just my experience in presentations and what is required and accepted in workmanship. And Hey, I LOVE the idea, as it gave me another variation/way to do more game activities, hunt and search etc. The layer of wood behind, or background also protects the mounting surface behind the frame as well. Kids are rough on things! Thanks!!</p>
<p>I definitely see where you're coming from. What I mean is that I find it dishonest to the <em>material. </em>The nature of plywood is that it's layers of wood veneer stacked on top of each other with alternating orientations for strength, and it's in the form of a larger panel that is cut up for use. When it's cut, the edge exposes these layers.</p><p> I understand that using veneer edging or otherwise hiding the exposed edge is considered proper finishing (most people would agree), it's just that I have a deep-rooted instinct (no doubt leftover from studying architectural theory) to let a material present itself as it really is. To me, using veneer edging is an effort to make something that is not solid wood masquerade as solid wood.</p><p>I guess at the end of the day I'm trying to ennoble something that's humble, like plywood that can be found at any Home Depot.</p>
<p>This is also a great idea for Exhibits too...topic or visual on one side, flip it out to read the info on the topic! Great idea!! Thank you!! The idea of the hole at bottom to push it up is great, but just a 'c' shape at the top lets you pull up the panel or record too. :)</p><p>cheers! Vicki</p>
<p>Good call!</p>
<p>Do you really need the closed back? Woulkdn't it be sufficient to just have the square frame?</p>
<p>I was just thinking that this would look really nice in hard wood. With that material, it wouldn't make sense to have the closed back- you'd just do mitered strips of wood with a groove in the center for the record. Good call!</p>
<p>great idea. I will add a front &quot;glass&quot; with UV barrier to prevent fading.</p><p>the &quot;glass&quot; will probably be plastic. </p><p>As others have mentioned, this concept will work great for other items as well. </p>
Hi, the common plastic &quot;glass&quot; is barely UV barrier. It will be cheaper and easier to use standard window's glass
Polycarbonate
<p>Thank you ddw_az! </p><p>Yes, you are right. What a great material! I've read more about polycarbonates and I will abandon acrylic glass (plexi, PMMA) for my projects from now. </p>
<p>I thought about that, but I couldn't think of an elegant way to get the record out without adding a cutout somewhere in the front panel so you can grab it.</p>
<p>Set Up a finger hole on the bottom, that is not visiable from the front to push up[ the record and then pull it out from the top.</p>
i have been trying to wrap my brain around that problem. thought about a string sling, pull the string and lift the record, but the string would cut the cover. <br>or put the slot on the side, tilt frame and record rolls out. could be dropped and damaged. <br>i have other projects with higher priority to do.
<p>A slot on the side seems like a great solution to me...</p>
<p>Another solution is to create a small slot at the bottom of the back three pieces so you can just poke it up with your finger.</p>
<p>Great idea!</p>
I now have a great idea for my &quot;West Side Story&quot; vinyl.
<p>Curious what kind of laser cutter you used for this? Great job!</p>
<p>I did this on an Epilog 120W. Obviously the cuts are fast and precise, but you have to sand off the scorched edges which adds more time. It's probably a wash in the long run between doing it on a laser and doing it by hand. </p><p>If you don't have access to a laser or just want to make the piece without having to worry about cleaning up the burn marks, try the method from my <a href="https://www.instructables.com/id/Digital-Fabrication-By-Hand/">Technique: Digital Fabrication By Hand</a> instructable.</p>
<p>This is awesome! Totally going to attempt this.It'll make a perfect Christmas present for my brother :)</p>
<p>Awesome! Post and IMadeIt!</p>
<p>Thank you, thank you, thank you!</p><p>I will give it a go with your &quot;Digital Fabrication By Hand&quot; method</p>
<p>That's what I like to hear! This is an easy one for that method. Please post and IMadeIt!</p>
<p>I made a similar frame to park the cover of the record being played.</p>
<p>very creative and cool project :)</p>
<p>such a simple idea, really nice work</p>
<p>Thank you!</p>
<p>Im seriously considering if this method could be used to frame more things like cd's and even comics</p>
Nice work! The Kraftwerk LP realy deserves it.
<p>Maybe the best album cover ever...</p>
<p>With Berlin (Lou Reed)</p>
<p>Oo wonderful idea. Oh and this would be great for any media room or music and art lover. But I would be careful where you display these on a wall. Make sure you pick a spot on the wall where the sun doesn't shine directly also making sure that the temp is fairly consistent. </p>
<p>This is fantastic! You should really look into selling these...I would totally purchase some! </p>
About This Instructable
59,300views
987favorites
License:
Bio: I'm a full-time Designer at the Instructables Design Studio (best job ever). My background is in residential architecture, film set design, film animatronics, media ... More »
More by JON-A-TRON:Giant Knob Lamp How to Design a Fidget Spinner How to get started with CNC
Add instructable to:
