Vinyl Record Shelf
1,523
44
6
Published
Introduction: Vinyl Record Shelf
A shelf to store your vinyl records for less than 5 €
( Me, she even costed me nothing at all, 100% recovery)
Well, it will take 3 or 4 vinyl sacrifice !
Step 1: What You Need
board pallet
screw
equerre metal
vinyl record
painting
Sandpaper
Step 2: Structure of the Shelf
Sand and cut the boards according to the dimensions you want to have
Step 3: The Body Frame
After assembly with screws and equerres , I put a little gray paint to have an agreement with our finishing salon.
Step 4: Reccord Vinyle
To bend the disc. It must be heated .
I use a heat gun , as I slowly pass at the crease . By blocking out the disc , we get to make regular fold. Be careful not to overheat the same place , otherwise the vinyl will quickly begin to melt.
Step 5: Finish
Then I drilled discs to fix on the board.
(I think I'll have a little strengthening drives because they tend to fold when it stores the other drive)
(Sorry for my very bad english)
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    LOVE this idea and the clarity of the 'ible. Great job!
    I made some improvement.
    By folding a thick sheet metal 15/10e mm to reinforced discs, i can put more record on each level.
    Adding also a disc in the lower part to block the other record .
    Capacity: 60 records
    Very good idea and smart design. Unfortunately I cannot make it, none of my LPs deserves to be broken.
    Great work!
