Visco Fuse Bottle Rockets
 by Dandeman321
Featured
This instructable will show you how to make your own bottle rockets using Visco fuse as propellant. Visco can be purchased at many online stores. I buy mine from the local firework wholesale shop. I am not taking any credit for this design, I have just modified it. The changes I've made have been mostly weight reduction. I have made changes to the bamboo skewer, the crimping method, the crimper spacer, and the amount of computer paper used. In my first test, I noticed that the rocket did not shoot straight up but off to the side. This could have been due to a few different reasons but when I reduced the overall weight and crimped it a certain way, it seemed to fix it. This was also posted at skylighter.com as well and originated from a book written by Lancaster.
***Just a quick side note: I do not take any responsibility for your actions while constructing this firework, or any others presented to you, by myself. ***
Step 1: Gather the Required Materials
You will need:
(1) Hot Glue Gun
(1) Drill with 1/8 inch bit
(1) 1 in X 3 in strip of masking tape
(1) Glue Stick
(1) 2.5 in length of Visco Fuse
(6) 1 in lengths of Visco Fuse
(1) 1.75 in X 5 in strip of computer printer paper
(1) Ballpoint pen **Make sure it has a slightly rounded end
(1) Length of twine or string
(1) Bamboo Skewer
(1) Pair of scissors
Optional:
Various powdered metals, such as Zinc, Aluminum, or Titanium
1-40 of 242Next »
suberk says: Feb 18, 2013. 5:38 AM
Very good idea.
BCSTechie says: Feb 17, 2013. 12:10 PM
I've got some fuse, (+100) which burns REALLY fast, like 1 sec/ft fast. Will this still work? Or will it just blow up the paper casing due to the extreme pressure? Has anyone tried this with this kind of fuse?
Dandeman321 (author) in reply to BCSTechieFeb 17, 2013. 5:40 PM
Hrm, yeah, that may blow up. Might as well try! If it does you just have a nice firecracker.
bjc4073 says: Jan 1, 2013. 10:20 AM
greatness! mine do circles and i love it
Toga_Dan says: Sep 4, 2012. 10:03 PM
Is the crimp a restricted nozzle?
Dandeman321 (author) in reply to Toga_DanSep 5, 2012. 7:22 AM
Yup! It provides the directed lifting thrust needed for the rocket to launch. Once it's flying, the nozzle will burn away but the burning fuse is enough to keep it in motion.
toezar00 says: Sep 4, 2012. 3:30 PM
Cool....Very Cool
thebutler says: Aug 22, 2012. 2:53 PM
thank you so much this is awesome i made one and it works awesomely and i love it
Dandeman321 (author) in reply to thebutlerAug 24, 2012. 2:29 PM
Glad to hear it!
Dguy42 says: Jul 6, 2012. 8:32 AM
could you use 3mm chinese visco that burns at a rate of 28second per foot
Dandeman321 (author) in reply to Dguy42Jul 6, 2012. 9:07 AM
Yeah that sounds like it would work. Light a test piece and put it on a hard surface. If it starts shooting around and moving quickly then you're good to go. If it just sits there and burns without movement, it probably wont work.
Dguy42 in reply to Dandeman321Jul 6, 2012. 11:19 AM
what kind of fuse would u recomend
Dandeman321 (author) in reply to Dguy42Jul 9, 2012. 6:11 AM
I just used the kind that the local firework store carried. Any type of fast burning cannon fuse should work. I don't have specific details on what type I used. It just came in a clear package labeled cannon fuse.
Dguy42 in reply to Dandeman321Jul 6, 2012. 10:25 AM
thanks, i just ordered some from cannonfuse.com.... Lets hope it works
airgunguy123 says: Jun 12, 2012. 6:31 AM
could you make it from cannon fuse
Dandeman321 (author) in reply to airgunguy123Jun 12, 2012. 7:06 AM
Yeah, I believe cannon fuse is the same as visco. For a quick test, take an inch or two of your cannon fuse, lay it on the ground, and light it. If it starts spinning around and going all over the place, it should produce enough thrust to be used for these rockets.
airsoftdominator999 says: Jan 25, 2011. 8:40 PM
could you also use flying fish fuse for the 1 inch pieces? i want to make these with color but i dont wanna use metals
Dandeman321 (author) in reply to airsoftdominator999Jan 26, 2011. 4:13 AM
I'm not entirely sure... I've never used any flying fish fuse so I don't know if it would work. It looks similar to visco so the thickness would be about the same but I don't know how much thrust it will put out. Give it a go! That's a good idea!
airsoftdominator999 in reply to Dandeman321Jan 26, 2011. 7:08 PM
well, it said on the site that it put out a TON of thrust, so i think it should be fine, maybe even better.
Dandeman321 (author) in reply to airsoftdominator999Jan 27, 2011. 5:00 AM
K cool! Give it a go! Let me know how to works!
tomass1996 says: Nov 28, 2010. 4:45 PM
does anyone know wher to buy this that will ship to new zealand??
C1hrisin123 says: Nov 13, 2010. 10:55 AM
Thats A UK SITE
http://www.wirelessfireworks.co.uk/fuse.htm
AND YOU CAN GET THE CHEMICALS FROM
http://www.inoxia.co.uk/
lockpick says: Jul 5, 2010. 11:17 AM
I'm not allowed to buy stuff off the internet so where can I buy disco fuse in the bay are?
firefighter1333 in reply to lockpickJul 16, 2010. 5:16 AM
lol, you're not allowed? and wtf?! DISCO fuse?
lockpick in reply to firefighter1333Jul 17, 2010. 4:24 PM
Yeah I'm not allowed. My parents are really strict about what I do I proabably should find a beter hiding place for those F rocket motors in my closet. And curse the typo god about the disco.
thorpenny says: Jul 10, 2010. 1:02 PM
muhahahaha...
fireball9919 says: Jun 30, 2010. 7:36 AM
What is the thickness in the fuse that your using? does it matter??
Dandeman321 (author) in reply to fireball9919Jul 1, 2010. 6:42 AM
I believe it's just 1/8 inch fuse. Smaller or larger ones would probably work I would assume.
fireball9919 in reply to Dandeman321Jul 1, 2010. 7:11 AM
all right thanks a bunch :)
qwertyman10 says: Mar 24, 2010. 6:06 PM
You know, this looks like a good idea. The only problem is that I havent been able to find fuse of any kind anywhere, and ive needed it a lot. Is this just like the standard green fuse on firecrackers? and where can you get it?
fireball9919 in reply to qwertyman10Jun 30, 2010. 6:50 AM
hey these guys got everything. and its pretty cheap too http://www.mojopyrotechnics.com/
projectguy in reply to qwertyman10Jun 18, 2010. 3:44 AM
Get fuse from pyrocreations also
flamethrower1010 in reply to qwertyman10Apr 11, 2010. 1:20 PM
 Go to cannonfuse.com and get the economy flying fish fuse ($5 per 63ft) and some Chinese visco fuse ($5-5.50 per 63ft)- so far the flying fish fuse has worked better for me, it burns faster. shipping is not too bad only $7 compared to skylighter with $20 fuse and $15 shipping fees.
Colonel88 says: Nov 8, 2009. 7:36 AM
can u use match heads? Or can you use the powder from pop cap guns?
Jared8989 in reply to Colonel88Jun 7, 2010. 9:21 PM
no and no. just go to cannonfuse.com and get whichever fuse u like. with shipping it will probably cost under $20
Dandeman321 (author) in reply to Colonel88Nov 8, 2009. 1:17 PM
I don't think either of those would work. The matchheads burn too slow and the powder from pop cap guns is an explosive.
meat sack says: Dec 17, 2009. 9:45 PM
wer can i buy fuse
Dandeman321 (author) in reply to meat sackDec 19, 2009. 7:21 AM
Cannonfuse.com
smashbob says: Aug 29, 2009. 8:02 AM
r u sure u didn't mean an 1/8 inch of tape instead of a 1/4 inch. cuz that's a lot of tape for a little thing like a bottle rocket, and it doesn't look like the end product is even 1/2 an inch wide.
Dandeman321 (author) in reply to smashbobAug 29, 2009. 9:12 AM
What step are you talking about? I haven't worked with these in years.
1-40 of 242Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
