Volume Units Meter
Introduction: Volume Units Meter
                         This project is about how display an audio signal from a computer/mp3 (or any other media player device's) audio jack by glowing the LED's. Normally voltage is measured and displayed on an LCD or a seven segment display but displaying a voltage in this form is very simple and attractive
                        A Volume Unit (VU) meter or Standard Volume Indicator (SVI) is a device displaying a representation of the signal level in audio equipment.
                        Now the aim was to make a vu meter that senses the volume and accordingly glow led's ... the more the amplitude the more number of led's glow. the IC i have picked for this purpose is lm3916 Dot/Bar Display Driver
                           General Description
The LM3916 is a monolithic integrated circuit that senses analog voltage levels and drives ten LEDs, LCDs or vacuum fluorescent displays, providing an electronic version of the popular VU meter. One pin changes the display from a bar graph to a moving dot display. LED current drive is regulated and programmable, eliminating the need for current limiting resistors. The whole display system can operate from a single supply as low as 3V or as high as 25V.
                            The IC contains an adjustable voltage reference and an accurate ten-step voltage divider. The high-impedance input buffer accepts signals down to ground and up to within 1.5V of the positive supply. Further, it needs no protection against
inputs of ±35V. The input buffer drives 10 individual comparators referenced to the precision divider. Accuracy is
typically better than 0.2 dB.
                             Audio applications include average or peak level indicators, and power meters. Replacing conventional meters with an LED bar graph results in a faster responding, more rugged display with high visibility that retains the ease of interpretation of an analog display.
                              The LM3916 is extremely easy to apply. A 1.2V full-scale meter requires only one resistor in addition to the ten LEDs. One more resistor programs the full-scale anywhere from 1.2V to 12V independent of supply voltage. LED brightness is easily controlled with a single pot.
Step 1: Things Required (temporary)
                         in-case u want to make a temporary project  u will need
*bread board
*ten LED's different color (your choice )
*a potentiometer 5k or at least greater than 2k
*an ic lm3916 dot/bar display driver
*connecting wires
* and a power supply (i use 12v power supply) or a 12V DC adapter
schematics of how to make connections  are uploaded in 3rd step
in case someone wants to make his/her own power supply here is the link
Step 2: Things Required (permanent)
                         in-case u want to make a permanent project  u will need
*PCB of 10cm x 10 cm at least
*Etching equipment
*soldering equipment
*Mini drill for drilling the through holes
PCB layout  is uploaded in 3rd step
i used HCl (Mutaric acid) and H2O2 as etchant its perfect
Step 3: Helping Files(sechmatics/datasheet/layout)
Here are some of the helping material u might need for the project
*datasheet for the ic (in .pdf format)
*schematics (opens with proteus software)
*PCB layout (opens with proteus software)
Step 4: Video
Check this video i made it  just as a demonstration
in case of any problems u can mail me at dinitrogenoxide@ymail.com
Enjoy and if u like this instructable rate it and like the video
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    I need a circuit to measure volume on a speaker level output (could convert to line level) then provide output which varies resistance based on level. Trying to use speaker level out to set volume of a second amp which uses simple wired potentiometer to set volume output. Any suggestions?
    This VU meter can be used to do this. however this is not continuous. you can not get a continuous range from this circuit. However if you decide to divide your total resistance into 10 levels(you can increase and decrease this according to your need) and then depending upon these outputs you can connect transistors to activate different values of resistance in your second Amplifier.
    Let me know If something is confusing.
    I made one with lm3915 but that ic was shortcircuited i replaced it with shop to 3916 i will make this.
    Do give it a try :)
    What is the function of potentiometer? How to know the wire from 3.5mm audio jack is ground and other?
    Thank you.
    Hi mardikusmo, the function of potentiometer is to control the sensitivity of the Vu meter like for example if u are playing a song that is at a very low volume u can change the sensitivity so that it divides the voltage on all the LED's otherwise only 2-3 LE:D's might glow due to less voltage.
    Secondly the sound is an alternating voltage signal i.e. it changes polarity every instance so u don't need to take care of ground.
    and still if u need to find the common wire the one labeled orange in the pic is common the other two are for left and right indivisually :)
    like and fav :)
    Can you use microphone for this project and how? Pls reply..
    hi..its a nice project..however could u give in details,about the input signal..pls list the required components and the procedure to take the input... well thanks in advance :)
    Thank u :)
    u can take input from any media player /Mp3/mp4/Cell Phone/Computer device. all u have to do is buy a 3.5mm Audio Jack and solder 2 wires one one the ground terminal and the other connecting the other 2 terminals. now plug it in the computer and the other side in ur circuit.
    Thanks again.
