Vodka Bottle Coffee Table
 by pipe42
Step 6: Support Pieces
The support pieces are very simple. I made my support pieces with a 45 degree angle at each end, so they wouldn't be so obvious when the shelf is made.
If you have solid wood shelves, or solidly glued up shelves, then supports won't be necessary.
The supports do help to provide more depth to screw the tuckbuckle hooks into, and also helped pull all my ever-so-slightly-wonky boards into a single flat plane.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
