Voice Control 9W 220-240v BULB Using ARDUINO+ANDROID
1,843
53
Posted in TechnologyArduino
Introduction: Voice Control 9W 220-240v BULB Using ARDUINO+ANDROID
About: College student.. Arduino, Raspberry pi and 3d printer lover !
Hi guys in this instructable I'll show you how to control (9W 220-240V) BULB using arduino and android phone.
Step 1: ‚ÄčComponents Required
1) Arduino Uno
2) Bluetooth Module HC-05
3) Relay
4) Bulb 9W 220V (obviously :D)
5) Breadboard
6) Bulb Holder
7) some jumper wires
8) Android Smartphone
Step 2: Connect Bluetooth and Relay on ARDUINO
In Bluetooth Module HC-05 have 6 pins but we're using only 4 pins
RX (Receive Clock )
TX (Transmit Clock )
5V
GND
And Relay have mainly 3 pins (if you're using 1ch relay)
VCC
GND
IN1
-connect the bluetooth rx pin to the arduino tx pin
-connect the bluetooth tx pin to the arduino rx pin
-connect the relay and bluetooth 5v and vcc pin to the arduino 5v pin using breadboard
-connect GND pin same as a 5v.
note : 1 connection is remain i'll show you in next step.
Step 3: RELAY Connection
So now in relay have 3 connection(shown in image)
NO - Normal Open
C - Common
NC - Normal Close
-Normal Open(NO) connect to the bulb Positive.
-Common connect to the plug positive.
-bulb another wire connect to the plug's second wire.
so here all connection is ready !
Step 4: Arduino Code
// NOTE : in this code i'm using CH3 but its depend on which channel you're using so if you use channel 2 then you type the( CH2 7 ) and 7 is the number of pin which we connect through the channel 2 //
String voice;
#define CH1 7
void setup() {
Serial.begin(9600);
pinMode(CH1, OUTPUT);
digitalWrite(CH1,HIGH);
void loop()
while (Serial.available()) {
delay(10);
char c = Serial.read();
if (c == '#') {break;}
voice += c;
if (voice.length() > 0) {
Serial.println(voice);
if(voice == "*switch on") {digitalWrite(CH1, LOW);}
else if(voice == "*switch off") {digitalWrite(CH1, HIGH);}
voice=" ";}}
Step 5: Download the Android App
https://play.google.com/store/apps/details?id=robo...
after download the app
go to the connect robot
and say switch on and switch off !
THANK U :)
if any query then ask me... comment section below
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    3 Comments
    hello sir , how to add this code to arduino library ? there is no .h file , sorry im new
    Sir! Your work is great! Ahm, I would like to ask if it is possible for us have more than one output aside from the 220V bulb? Just like making a Home Automation
    This is really cool. It would be great to hook this up to control the coffee maker. That way the coffee is already there when you get to the kitchen.
