Voice Controlled LED Using Arduino and Android Mobile
Published
Introduction: Voice Controlled LED Using Arduino and Android Mobile
About: I am Freelancer at Home.
In this project I will control a LED using voice command. To implement this project we need to arrange some stuff like:
1. Bluetooth Module
2. Arduino UNO
3. Android Phone
4. LED with resistor
5. And a android app namely “amr voice”
Step 1: Description
Working of this project is simple. First of all we need to connect LED and Bluetooth module with Arduino.
After it upload code in Arduino.
Step 2: Download AMR Voice App From Google Play Store
Now download AMR Voice App from google play store and
install it. And open it
Step 3: Connect App With Bluetooth Module
Step 4: Try It
After successfull Connection between mobile and bluetooth module now tap at the mic symbol in app screen and
say “light on” to turned on l and “light off “ to turned off the LED
Step 5: Circuit
Connection are simple. Connect a LED at any pin of arduino. In my case I used 12. Connect rx and tx of bluetooth module to software serial pins tx(11) and rx(10) of Arduino respectively. And connect power supply to bluetooth module.
Step 6: Coding
Coding is much simpler. Here I have used SoftwareSerial
library to enable virtual Serial port at pin 10 and 11 of arduino.
Step 7:
And in given picture I have compare received string with predefined string to take some needed action.
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    where can i get full code
    So I'm planning on doing a short stand-up routine with an Arduino powered dummy. Can you tell me if this is accurate enough to respond to phrases or words within sentences?
    Fun Arduino project. This could let you voice control all kinds of circuits.
