loading
Step 6: Updates: A living instructable (11/3/12)
I am so happy that this instructable won me a prize, I've desided to revisit it, and update it with changes I've made.  Two quick changes this morning
  1. I added a sleep statement at the beginning of the loop.  The logic is "If state=waiting, then wait 1 second."  This means I have to hold down the * key to start dialing, but it's a small price to pay to go from 100% CPU utilization to 25% utilization.  Code:
    if (state==waiting):
      time.sleep(1)
  2. I added the ability to stop dialing.  Previously, while waiting, you'd press * to start dialing, then if you made a mistake, you'd press * again to start dialing all over again.  I've added some code that checks to see if there is a current number in the buffer.  If there is, it will reset dialing, but if not, it will go back to waiting.  Code:
    elif (state==dialing):
      if (keyPressed=="*"):
        if (string1==""):
          state=waiting
          showStrings("","Waiting")
        else:
          string1=""
          showStrings("","Dialing")
So that's two things that I was able to "knock off my list" of "what's next" from the last step.  There might be more coming!
<p>I've been using magicJack for a few years now and like it overall. I switched my business number over to mj last year but am totally overkill by running it on a Mac mini. But today I thought of using a Pi and that led me here. Will following you instructable allow me to use the Pi with MJ even if I don't use the Google Voice? Really hope so. Thank you</p>
<p>This doesn't use the MagicJack directly on the RPi, unfortunately. It allows you to dial a number and have the RPi connect with Google Voice, telling Google Voice to call your MagicJack number, and connect you to the number you dialed.</p><p>Let's say your MJ number is (123) 456-7890, and you want to call a conference call at (987) 654-3210. You try to call that directly on your MJ, and you're told you have to use MJ's conference call system. You have no control over where the call is hosted, so you can't do that. You need to get through to (987) 654-3210.</p><p>This system lets you dial that number, then connects to Google Voice, tells Google Voice to call your MJ at (123) 456-7890, and when you pick up, to then connect you to (987) 654-3211.</p><p>Basically, your MJ line will ring, and when you pick up, you'll hear ringing, and then you'll be connected to the conference call.</p><p>You can do this directly with Google Voice on the web, but that requires the extra step of connecting to the website. This system lets you have a dial pad on your desk, ready to go.</p>
Great project! <br> <br>I have been trying running google voice on RPI too.. But it keeps giving &quot;googlevoice.util.LoginError&quot; error. As I googled it I saw that It is a common problem but i couldn't solve it for raspberry pi. <br> <br>Have you encouraged this problem? How did you solve it? <br> <br>Thanks.
I did encounter the problem. I came across a fix for it where you have to make a change to the URL for the authentication.<br><br>In settings.py set LOGIN to &quot;https://accounts.google.com/ServiceLogin?service=grandcentral&amp;passive=1209600&amp;continue=https://www.google.com/voice&amp;followup=https://www.google.com/voice&amp;ltmpl=open&quot;<br><br>Is the solution that worked for me, I think.
This project is pretty awesome! I've been pondering a dialpad built into my Vonage box, but it's pretty limited. This project seems like a pretty awesome way to also build a SIP phone of sorts potentially with a speaker and all, a cheap-as-hell SIP phone. Nice job! <br> <br>The only thing I could think of that'd also be cool is being able to use your Magic Jack with Linux on the Pi, but I highly doubt the project's built in any sort of Mono-compatible language you could run it under. Still a neat idea, too bad WINE isn't ARM-compatible!
I use the &quot;you don't need a computer&quot; version of Magic Jack, so it doesn't even plug into my WIndows computer (they don't make a Linux version, btw).<br><br>I've thought about the SIP phone solution, and that's where I really would like to go. USB Headset and what not. I tried getting some stuff setup, but couldn't get it working so I settled on this.<br><br>I could include listening to voicemail via a speaker, I think. The pygooglevoice code allows for downloading voicemail as MP3s, so it shouldn't be that hard.
this project is awesome, great use the pi and very original! great documentation as well. excited to see version 2
Thank you so much!
About This Instructable
33,518views
108favorites
License:
More by mrmath:Running an HD44780 Display off the ATmega on a Gertboard Voiceberry Pi! Driving an HD44780 Display using a Shift Register and a Raspberry Pi
Add instructable to:
