Voldemort's Wand
7,618
109
8
Posted
Introduction: Voldemort's Wand
Follow these instructions to make your very own... Dark Lord wand.
Step 1: Items
You will need:
- Polymer clay
- Sculpting tools
- Microwave oven
- Hot glue gun
- X-acto knife
- Chopsticks
- White paper
- Assorted paints
Step 2: Base
Start off by gluing the paper on the chopstick and rolling the chopstick to make a very thin funnel shape. It should be about 5-6 inches long.
Step 3: Sculpting
Sculpt the handle on the wand. This will take some time so don't rush, use some pictures as reference if needed. When finished test fit it on the base. I baked mine for about 30mins at 270.
Step 4: Locking Mechanism
I cut a peice of wire from a coat hanger that I then glued to hold the handle and chopstick together to make the wand. *I did this after painting both of them*
Step 5: Paint
Give the wand parts 2 coats of white and then touch up with brown and black. I waited about 15 minutes between each coat. I glued them together after they were dry.
Step 6: Stand
This is a simple stand that was composed of 3 peice of cardboard.
Step 7: Finished Wand
Taa Daa! You are now a Dark Lord! I hope you enjoyed this tutorial.
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
8 Comments
I make mine into a dip pen by making the girth(7/8" in girth) much larger to tolerate a 1/4" diamond bit. I made this part out of ceramic with a metal rod inserted to strengthen the wand part. Instead of using ceramic for the top part, i used lightweight silicon putty called sguru so that i could stick it on the other end. if you make this, make sure that you account for everything or you will have wasted about $5.50 - $12
Great project! I would probably use a wooden dowel and carve it to a point, thereby eliminating the edges of the paper that spiral around the wand. One thing though, I thought in the movie that Voldemort's wand was actually crooked? Guess I'll have to watch it again.
Actually I just looked it up, its not crooked. sorry.
I didn't have a big enough dowel and It is crooked in the movie, I was just using up what I had. Thank you though. ,:)
Love the paint job, might want to make a more majestic stand though =3
Haha thanks. I'm going to make a hook like area for it to rest on.
