Voltage Controlable Atari Punk Console
 by janw
Contest WinnerFeatured
A while ago, I decided that I wanted to build an analog modular synth. After doing some research, I found out that I didn't know all that much about analog audio electronics at all. So the best thing to do was to start from the very beginning and to build all kinds of simple oscillating circuits to get a grip on the basics.
When you google for simple oscillators, you inevitably come across the stepped tone generator aka the Atari Punk Console (APC). The circuit was first published in 1980 by Forrest M. Mims III and was later slightly altered and renamed Atari Punk Console by Kaustic Machines. They gave it that name because its sound resembles that of the old Atari video game consoles.
When I did build my first APC, I quickly discovered why it is so immensly popular. It is very cheap and easy to build and it produces a lot of weird and funky noises with very few parts.
The only thing that, imho, is missing in 90% of the available circuits online, is a way to add an external voltage control.  It can be done by adding only two extra female Jack connectors to the two free pins on the 556 timer. WIth these two extra connectors, you can add an external oscillator, LFO,...
Step 1: What do we need for this project?
  • A 556 dual timer
  • A 1K resistor
  • An LED of your choice
  • A resistor for the LED. In my case a 470Ohm
  • A 100nF and 10nF capacitor
  • A 10uF electrolytic capacitor
  • 2 x 470K or 500K potentiometers
  • A 100K Logaritmic potentiometer or a 100K and 4K7 resistor
  • A switch
  • 3 female jack connectors
  • A DC connector
  • A 9V powersource
  • A case. I used a plain and ready available project box. But google for Atari punk console and be amazed about all the weird and wonderful housings for this device. I am sure that you can come up with one of your own.
crth says: Feb 18, 2013. 12:59 PM
could someone tell me what program the circuit was drawn on
janw (author) in reply to crthFeb 19, 2013. 1:42 AM
I draw all my circuits in Eagle.
poofrabbit says: Nov 29, 2012. 8:37 PM
Congratulations on being a finalist in the DIY Audio Contest!! Good luck to you!
janw (author) in reply to poofrabbitNov 30, 2012. 1:51 AM
Thank you!
synthdust says: Sep 29, 2012. 12:09 AM
All the other APC only use one 556. Is the second one here need for the output mods? I am obviously very new to this, so please be kind ;)
synthdust in reply to synthdustSep 29, 2012. 12:11 AM
Never mind, I just figured it out!!!
janw (author) in reply to synthdustSep 29, 2012. 1:29 AM
No problem, I myself am also sometimes confused when seeing those broken up IC schematics.
Insonicbloom says: Sep 20, 2012. 6:58 AM
cool project - if you want to build another cool little instrument I have a stripboard layout for a theremin thats pretty easy to build - it's an Aerial version not an LDR one
HERE
janw (author) in reply to InsonicbloomSep 20, 2012. 1:33 PM
It makes a great sound! I've put it on my 'to make'-list.
skuishingbugs says: Sep 17, 2012. 7:49 AM
where did you get the pcb?
janw (author) in reply to skuishingbugsSep 17, 2012. 8:51 AM
I designed and etched it myself.
skuishingbugs in reply to janwSep 17, 2012. 7:55 PM
Can you upload the file you used?
janw (author) in reply to skuishingbugsSep 18, 2012. 11:54 AM
I added the eagle file for you. Read the note that I added on the last step about the output.
skuishingbugs in reply to janwSep 19, 2012. 7:46 AM
thank you!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
