Voting System by Using 4-bits Parallel Adder
6,671
76
7
Posted
Introduction: Voting System by Using 4-bits Parallel Adder
Hello! friends
Welcome to my another voting system by using 4-bits parallel adder project. It's a topic of Digital And Logic Design by Morris Mano (fifth edition) with the help of this project you'll know how voting system works in reality.
So let's get started.
Step 1: Circuit Diagram
With the help of this diagram we can build our own voting system project very easily. Just follow the diagram very carefully. Let me tell you something at the pin 14 of 74ls47 a 330 ohm resistor is attached with 7 segment led's which is not mention in a diagram by mistake.
Step 2: Materials
You'll need
Ic's: (74hc283 x 2), 74ls47 with x3 16 pin bases and Lm7805 (regulator)
Veroboard
Some pieces of jumper wires
Solder
Led's: (red x 4), (Green x 6)
7 segment led's x 2 (Anode)
Resistor's: (330 ohms x 12), (1 k x 7)
Switches: spst x 7
Step 3: Component Placing
Place the components according to the diagram on veroboard and soldering it.
Step 4: Soldering and Jumper Wires
This is the back view of voting system project with some solder and jumper wires.
Step 5: Finish
After completing the all steps it's look like this and ready to use. In next step a small video about voting system.
Step 6: Video
Here it's the video watch it carefully and you'll know how it's work.
Thanks for watching.
I hope you guys like it. I'll be back with some new awesome projects.
  • LED Contest 2017
    LED Contest 2017
  • Raspberry Pi Contest 2017
  • Voice Activated Challenge
Questions & Answers
7 Comments
I did not find the video at the 6th step, please can you reupload it!
IS IT USEFULL EVEN FOR A DMX ADDRESS?
Just my failed attempt at some levity. In Part 2 you said:
"You'll need
Ic's: (74ls283 x 2), 74ls47 with x2 16 pin bases and Lm7805 (regulator)..."
It did not match with your layout.
Oh thanks now I know what you mean I wrote 2 bases except 3 in step 2 k I'll improve it thanks bro.
Just to show you I really read these things, where did you hide the 2nd 74LS47? You said we needed two in Step 2 but only one appears in the schematic and your layout.
I'm using two 74ls283 and 1 74ls47 where is the hidden 74ls47
