3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vumeter Light Deco
Vumeter Light Deco
I will show you how i made this nice and easy to make light-decoration for your next party or just for your living room. The lamp lights up in a vumeter-style when music is playing - in fact it IS a vumeter... For that reason it needs an audio input you have to connect it to the line-out of your music device.
See the video to get an idea of it:
Step 1Parts, Tools and Skills
Parts:
10 LEDs
1 Current limiting resistor (R1) - value depends on your LEDs
1 2,2µF Capacitor
1 LM 3915
1 mono audio jack with cable
some pieces of wire
1 piece of protoboard like the Mini Board from Radioshack
1 soldering strip (i used it because i had one, you could also use a piece of cardboard)
1 little switch
1 piece of sandwich paper or similar kind of paper
1 high glass or glass cylinder
1 9 V Block battery and battery clip
optional:
for testing the circuit before soldering a simple breadboard could be fine.
1 piece of black paper for holiday decoration
Tools:
Soldering iron and solder
Wire stripper
Hot glue gun
Diagonal Cutters
optional:
Multimeter
"Handy Hands" or "Third Hand" (if you like you could build your own)
Desoldering tool
Skills:
- you should have basic soldering skills (Instructable How to solder)
- using your multimeter (Lady Adas Multimeter How to)
- some basic informations about LEDs (LEDs for beginners Instructable)
2 comments
Mar 21, 2010. 3:39 PMb3tn01hasd1s says:
 I will be using 5 green leds(link) 2 yellow leds(link) 2 orange leds(link) and 1 red led(link). I believe the yellow, orange, and red have the same specs. but the green one is different. What kind of resistor should I put. and by you saying 100 ohm resistor do you mean per led then times that by 10?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:mischka(resistor)
I like to play with electronics and other fun stuff, modify things to make them more useful or just more funny, putting things together that seem not to fit to make funny stuff. Sharing ideas make the...
more »
