Introduction: WALL-E Walk by Makeblock
This project shows you how to make a WALL-E robot that could walk around and shake his head and hands. learn more from openlabor website
Step 1: Part List
· ·1 x Beam 0808-072
· ·2 x Beam 0824-032
· ·2 x Beam 0824-064
· ·1 x Beam 0824-080
· ·3 x Beam 0824-112
· ·5 x Beam 0824-128
· ·5 x Beam 0824-144
· ·5 x Beam 0824-160
· ·1 x Hardware Robot Pack (Stainless Steel Screws)
· ·19 x Socket Cap Screw M4x14
· ·5 x Socket Cap Screw M4x16
· ·4 x Timing Pulley 62T
· ·6 x Timing Pulley 90T
· ·8 x Flange Bearing 4x8x3mm
· ·4 x Shaft Connector 4mm
· ·12 x Shaft Collar 4mm
· ·4 x Threaded Shaft 4x39mm
· ·2 x Base Bracket B
· ·1 x Me Orion
· ·1 x Battery Holder for (6) AA
· ·3 x Bracket U1-Blue
· ·3 x Bracket 3x3
· ·4 x Bracket 3x6
· ·3 x Plate 3x6
· ·4 x DC Motor-25 6V/185RPM
· ·4 x DC Motor-25 Bracket
· ·2 x Track with Track Axle(40-Pack)
· ·1 x 9g Micro Servo Pack
· ·1 x MG995 Standard Servo Pack
· ·2 x Cuttable Linkage 080-Blue
· ·1 x D Shaft 4x56mm
· ·5 x RJ25 Cable-20cm
· ·1 x RJ25 Cable-35cm
· ·1 x Me RGB LED
· ·1 x Me Dual Motor Driver
· ·1 x Me USB Host
· ·1 x Me Touch Sensor
· ·1 x Me RJ25 Adapter
· ·1 x Cross & 2.5mm HEX Screwdriver
· ·1 x HEX Allen Key 1.5mm
· ·1 x 2.4G Wireless Joystick
Step 2: Assemble Rectangle Frame
Step 3: Assemble Wheels
Part list:
1x Timing Pulley 90T
2x Flange Bearing 4x8x3mm
1x Shaft Collar 4mm
1x Threaded Shaft 4x39mm
1x Headless Set Screw M3x5
3x Plastic Ring 4x7x2mm
Step 4: Install Orion Board and Battery Holder
Step 5: Install Orion Board and Battery Holder
Part list:
2x Base Bracket B
1x Me Orion
1x Battery Holder for (6) AA
1x Bracket 3x3
2x Nylon Stud M4x30
2x Screw M4x22
8x Screw M4x8
6x Nut M4
Step 6: Replace.
Replace.Nylon Stud M4x30 with Brass Stud M4x32(included in the Hardware Robot Pack) as shown in the following picture
Step 7: Install DC Motors
Part list:
1x DC Motor-25 (185RPM)
1x DC Motor-25 Bracket
1x Shaft Connector 4mm
4x Screw M4x14
2x Screw M3x8
2x Headless Set Screw M3x5
2x Nut M4
Step 8: Follow the Same Steps to Install Another DC Motor.
Step 9: Assemble Chasis
Part list:
2x Beam 0824-144
3x Beam 0824-160
5x Beam 0824-128
16x Screw M4x22
16x Screw M4x14
16x Nut M4
Step 10: Assemble Arms
Part list:
1x Beam 0824-112
1x DC Motor-25 6V/185RPM
1x Beam 0824-032
1x Timing Pulley 62T
1x Bracket U1
2x Screw M4x16
6x Screw M4x14
2x Screw M4x8
2x Screw M3x8
Step 11: Follow the Same Steps to Assemble Another Arm.
Step 12: Assemble Tank Tread
Part list:
22x Track
22x Track Axle
Step 13: Adjust the Position of DC Motor to Install Tank Tread.
Step 14: Assemble Head
Part list:
1x Beam 0824-112
2x Timing Pulley 62T
2x Bracket 3x3
4x Bracket 3x6
3x Plate 3x6
4x Screw M4x14
4x Screw M4x8
4x Nut M4
2x Plastic Ring 4x7x2mm
10x Plastic Rivet R4060
Step 15: Install Electronic Modules
Part list:
5x RJ25 Cable-20cm
1x RJ25 Cable-35cm
1x Me RGB LED
1x Me Dual Motor Driver
1x Me USB Host
1x Me Touch Sensor
1x Me RJ25 Adapter
10x Screw M4x14
10x Nut M4
4x Plastic Ring 4x7x2mm
4x PH2.0-2P to Stripped-End Cable - 35cm
Step 16: Assemble Neck
Part list:
1x 9g Micro Servo Pack
1x MG995 Standard Servo Pack
1x Beam 0824-080
1x Beam 0808-072
2x Cuttable Linkage 080
1x D Shaft 4x56mm
1x Bracket U1
4x Screw M4x22
1x Screw M4x16
5x Screw M4x14
4x Screw M4x8
8x Shaft Collar 4mm
8x Nut M4
8x Headless Set Screw M3x5
1x Plastic Rivet R4060
1x Screw M3x8
Step 17: Wiring
Orange ports on Orion board: DC Motors of wheels
Me Dual Motor Driver: DC Motors of arms
Me RJ25 Adapter Slot1: Standard Servo
Me RJ25 Adapter Slot2: 9g Micro Servo
Port 1: Me Dual Motor Driver
Port 2: Me Dual Motor Driver
Port 4: Me RJ25 Adapter
Port 5: Me USB Host
Port 6: Me Touch Sensor
Port 7: Me RGB LED
Step 18: Programming
If you want to program Orion board from browser, you need to install the codebender plugin, unplug USB Host from Port 5, select board type Makeblock>Orion and correct port and click Run on Arduino. Then sketch will be uploaded to your board. If you prefer to program it with Arduino IDE, you can download the attached file and follow the instruction of ReadMe.txt file to run the program.
Step 19: Let's Walk Around
Plug USB Host into Port 5. Connect WALL-E with 2.4G wireless joystick. WALL-E is ready to walk around the world.
You can infer more information form my wetsite:www.makeblock.com/
