WEARABLE WASTE OF ENERGY by Plusea
Featured
Step 2: 9V battery, battery snaps and little pocket
Once you have decided on the layout and design of your wearable you will have to plan in one 9V battery for almost every component you integrate. This is because the conductive fabric traces have quite a bit of resistance, thus suck quite a lot of energy, which contributes to the whole “waste of energy” idea.
To connect the 9V battery snaps to the conductive traces, strip the ends of the wires that come out of the battery snaps and make a little loop. Solder this so that it does not unravel. Use conductive thread to sew the loop onto the end of the fused conductive trace.
You will want to make a pocket for your battery. Best to use stretchy fabric and cut it a bit smaller than the actual size of the battery so that the stretch will keep it in place. Also, make the pocket 2 or 3 cm longer than the battery, this way it stays in nicely, even when upside-down.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
