I had a Monark Lancer back then. A VERY COOL bike but no match for the Schwinn. Truth be told, it weighed more than Johnny, even when he had his usual pound and a half of pomade on his plebian ducktail. He developed legs like Popeye's arms.
OK, there's lots of old farts who are "into" the old bike hobby, and most of them worship horn tanks, springers, and authentic shiny paint and proper pinstriping patterns. Then there's the Whizzer subculture, devoted to those cruisers from the '40s and '50s which were powered by the legendary 148cc valve-in-head motor conversion of that name.
This bicycle--based on found junk and an April 15, 1955 Schwinn cantilever frame fronted by a JCHiggins double springer fork, is intended to be deranged--why else expend creativity and effort? To build a copycat or clone? Not here on Snob Hill, home of NoCal wallet-open creative constipation!
Ok, so we've got this old frame (Ebay find, sandblasted and rust-patinaed before we acquired it) and the oddball Cthulhu front end. Pop some new tires and rims on it for some cholo contrast. Fellow instructables denizen, Winged Fist, likened the seat to a medieval torture device, but it's comfortable as long as you're wearing pants.
The dashboard was also an Ebay find--some small-town Indiana MacGiver wannabee whipped it up from some old aluminum sheet, green reflectors, a lamp switch, his dad's mantlepiece Weather Station (brass clock, barometer, and thermometer) and then damascened it like the engine block of a Bugatti T57.
It is a work-in-progress; the headlight and taillight are both placeholders. We'll probably plasma-cut and TIG a new chainguard to match the Whizzer motor's recess. I know the crank set needs widening. We have to build a gas tank, and I want it to fit where the stock horn tank once resided--I think those Whizzer peanut tanks look silly straddling the frame top bar.
Progress reports as things move along. Right now the Toolcribbers are taking a rest while Andy creates CNC files to plasma-cut the engine mount brackets from steel bar stock.
Visit Our Store »
Go Pro Today »
Ive just started a whizzer conversion just the engine to go. here is a before and after photos. Do you have to bend the cranks to get the engine to fit?
There are two ways to go with this. You can buy a wider 3 piece crank and bottom bracket conversion like I did or you can also get a special wider crank set made specifically for Whizzer conversions.
In either case, Google will set you off in the proper direction.
Good luck with your conversion! We're working on a Whizzer powered board tracker right now.
http://www.instructables.com/id/Whizzer-Pacemaker-II-My-Latest-Time-Killer-Part-/
I do like your instrument dash better.
Here's a link to the video of the plasma cutter at work:
http://smg.photobucket.com/albums/v693/jingle_jangle/BICYCLE%20PROJECTS/?action=view¤t=P1010780.mp4
Using a combination of ty-wraps, MDF wedges and wire, we finally got the motor located, centered, wired into place, and stabilized so we can begin to sketch up the motor mounts. Andy and Michael will lay them out in Illustrator and we'll CNC plasma cut them on site. They'll be TIG-welded into place, and then the fun of adding the ancillaries begins.
I've got to come up with a gas tank, and since I think the factory belt guard is nasty, we'll be welding one up from steel strip and expanded mesh.
