Step 2Marking up
Because of the way the WII works it needs to 'see' the WII mote so that you can point at things. The only way I could do this was to take the top three sections out of the lightsaber.
Take the section that you have left and put the WII mote inside of it until it is snug. Take the pen and mark round the top, if you can't see it well enough then shine a lamp into it. Helps a lot
While you have the light shining in it. Or at least while it's in there. Take the time to mark up the A button and B button. We'll worry about the others later, these are the main ones.
Finally, on the side of the B button near the bottom of the lightsaber draw round the connector of the nunchuck. You're going to use this hole to feed through the connector so you might want to make it a bit bigger to make it easier on yourself.
Add Comment
