This is an "easy to use" music player with a reasonable sound quality. The main objective at the start of the project was that the box had to have only one cable, the mains. The way to achieve this was putting a chromecast audio inside the box. The rest of the electronics are just a low budget ebay class D amplifier and the power supply.
Step 1: Bill of Materials
2x 800x600x10[mm] playwood, €14.5.
2x 2400x33x9[mm] samba wood strip, €5.9.
2x 2400x98x9[mm] samba wood strip, €11.9.
Speakers, €26,90. https://www.amazon.es/Kenwood-KFC-E1365-Altavoces-...
Chromecast Audio, 39.
Amplifier, $9.96. http://www.ebay.com/itm/2-100W-TPA3116-D2-Dual-Cha...
Rotary Switch for volume, 2 pole 6 shorting (make before break), $9. http://www.ebay.com/itm/High-quality-Rotary-swtich...
Power Switch, €4. Local store.
Grill Fabric, €4. Ikea.
Transformer, €0. From an old halogen ceiling lamp: toroidal, 230:12,200VA.
Power supply parts, aprox. €10. From scrap and e bay.http://www.ebay.com/itm/401046113133
TOTAL: €140.
Step 2: Enclosure Design
The loudspeaker enclosure type I have chosen is sealed instead of ported so, the only parameter to dimmension is the volume of the box.
Step 3: Playwood Frame Building
The frame is joined with nails and glue.
Step 4: Covering With Samba Strips
The strips are fastened from inside the box with screws.
Step 5: Building the Speaker Holders
Step 6: Building and Attaching the Feet
Feet are made using a plug cutter and remaining samba wood.
Step 7: Building the Front Panel
Step 8: Fuse Holder, Mains Cable Hole and Transformer Holder
Step 9: Varnishing
Step 10: Foaming the Speakers
Step 11: Building the Grill
Step 12: Wiring and Assembling Electronics
The volume potentiometer has been substituited by a 6 positions 2 circuits switch that also has been wired to allow easy assembly in the front panel.
  • Pro Tips Challenge
    Pro Tips Challenge
  • Trash to Treasure
    Trash to Treasure
  • Science of Cooking
    Science of Cooking
Absolutely love this, I'm planning on making something similar but with switching inputs to connect a record player to it. It'll be a simple input switch to start with but eventually I want to use an esp8266 to switch using MQTT.
Thanks PaulS69 !! It would be great if you did the project and share the WIFI input switch.
I see you are using the Chromecast Audio. Can you only play music from streaming sites with it or can you play music from memory such as a harddrive? BTW: Nice job on the Speaker
I have the Google Chromecast (this has video functionality as well) and I love it! You can stream audio (either unit will work) from media sites and device memory. I've also set it up to work with music stored on an old computer running as a server. It basically lets anyone access the music on the computer over WiFi. Hope that helps!
Thank you for the Information.
Hello! If you are using Spotify (with a premium account), Google Play Music or similar you can select the device where to play directly from the application. If you want to play files, you can cast the sound from your computer/phone: in Android, from version 4.4.2, you just have to select the speaker in Options/Cast, in Windows/Mac OS you have to instal a sofware as described here http://lifehacker.com/how-to-send-your-computers-audio-to-a-chromecast-1750297581.
Nice cool projects. I had almost all the stuff, now motivated to find time assembling them. Kudos for a great project :)
Thank you! Luck with yours.
